fuel injectors
Old Mar 16, 2010 | 04:03 AM
last_'s Avatar
Car: 91 Camaro RS
Axle/Gears: stock...
fuel injectors
Hey, swappin in an LQ9 engine. Building from the ground up. Need to know which FAST fuel injectors to get. Probly going to run a relatively high lbs hour rating on my injectors and limit with a fuel pressure regulator.
http://www.fuelairspark.com/Products...rs'-0.aspx
follow the above link to see what i am lookin at. According to FASTs formula I need around 34 lbs hour for a roughly est. peak hp of 500.
I do not know if i need the high impedence or the low impedence.
Other than that... i will probly get a 65 lb hour injector to support future mods and limit with a fuel pressure regulator as stated above.
For now my engine will be naturally aspirated and will remain so for serveral years.
Thanks in advance for the help!
Old Mar 16, 2010 | 04:13 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
If it is going to be several years before the next power step, it would make more sense to get the proper injectors for your current configuration.
Old Mar 16, 2010 | 05:17 PM
NemeSS-TyranT's Avatar
Car: 02 SS
Engine: 408 TT (1108rw-93/m1)6700rpm
Transmission: TH400(slipping)
Axle/Gears: 12bolt/3.42(whines😠)
re: fuel injectors
i run 60lb hi imp. motrons in my car. with sd tune. with return fuel system and aeromotive fpr. 490rw n/a
a set of 42lbs will cover what u have now and flow more at ls 58-60psi pressure.the 42lb rating is at 43psi.
what are u setting your static fp at?
Old Mar 16, 2010 | 05:31 PM
Klortho's Avatar
Car: 1987 GTA
Axle/Gears: 9 bolt 3.70 posi
re: fuel injectors
I agree with what five7 said, I did the same thing in my Mustang and went with 30's instead of 24's and it ran like crap and really rich. I regretted it after I did it and ended up going back to 24's.
Old Mar 17, 2010 | 06:05 AM
last_'s Avatar
Car: 91 Camaro RS
re: fuel injectors
okay i went with the 36 hi imp precision fuel injectors. part number 303600
so, hopefully no issues with my l92 heads.
next question. kinda dumb, so bare with me..
the fast 102mm lsxr intake can go onto an lq9 with l92 heads, yes?
lol, feel free to go ahead and laugh.
Old Mar 17, 2010 | 08:04 AM
five7kid's Avatar
The 146102, or 146001 lower shell, yes.
Old Mar 18, 2010 | 04:39 AM
last_'s Avatar
Car: 91 Camaro RS
re: fuel injectors
okay, cause they came out with one specifically for the l92 heads that is different than the one that i got. i am deployed and dont want to get home in half a year to find out that i ordered the wrong damn intake.
feel me?
Old Mar 18, 2010 | 07:51 AM
Klortho's Avatar
Car: 1987 GTA
re: fuel injectors
The part numbers that five7 posted are for the L92 heads, it's the same one for the LS3/L76/L99 motors as well. Also, don't forget you may also need to go with the FAST fuel rail as well with it.
Old Mar 18, 2010 | 02:49 PM
five7kid's Avatar
"14 HP increase".
What is that, about $100 per pony?
Okay, okay, an LS3 intake will run you $375. So that's only $75/HP.
Old Mar 18, 2010 | 03:22 PM
Klortho's Avatar
Car: 1987 GTA
re: fuel injectors
$949.95 for the intake
$557.95 for the TB
$274.95 for 8 injectors
$1782.85 to get 26hp........
seems a little pricey to me.
Old Mar 18, 2010 | 05:04 PM
five7kid's Avatar
It could be argued that you would have to buy all of those pieces anyway. I'll be doing L92 heads for the '57 project, so I've got this staring at me in the near future.
I already picked up a new slightly damaged (vacuum fitting broken off that I won't be using anyway) L76 intake for $175. I'm looking at a 90mm TB for $425. I'll have to get injectors and fuel rails, haven't priced them yet - assume another $100 over your injector prices.
Assuming the 26 HP delta is real (and I'm skeptical), that's still $35/HP.
I'll live with 26 HP less.
Old Mar 18, 2010 | 06:03 PM
Klortho's Avatar
Car: 1987 GTA
re: fuel injectors
Oh, I'm sorry....I read on the wrong intake....DUH....this is what they say
Testing on a stock LS3 engine with a Big Mouth 102mm Throttle Body™ produced gains of 14+ horsepower and 11+ ft/lbs of torque at the flywheel over the stock intake.
The 26hp was on a 500ci LSx block engine with LS7 heads.
Now that combo makes even less sense to buy.
Old Mar 18, 2010 | 11:46 PM
last_'s Avatar
Car: 91 Camaro RS
re: fuel injectors
We'll say what you will but this is my first build. An maybe it's Just me but I think an lq9 w l92 ported heads fast 102 bigmouth msd ignition comp beehives an a lunati stroked assembly is pretty friggen sweet!!!! A lil on the pricey side but it will be a blast to drive .... And get tickets in. Lol
Old Mar 19, 2010 | 01:50 AM
five7kid's Avatar
The FAST probably gains more as the hairiness of the engine increases.
I expect my cammed 402 cid L92 headed LQ4 to easily outrun the current 396 in the '57 (even though it will just have an L76 intake. . .).
Old Mar 19, 2010 | 08:43 AM
Atilla the Fun's Avatar
On Probation
Engine: several
Transmission: none
Axle/Gears: none
re: fuel injectors
One of the mahazines just put a new Camaro SS into the mid 11s with the stock intake. They tried the FAST 102, and it was worth exactly NO improvement at all. even with Mast heads, Mast cam, headers, and exhaust, they still didn't need the FAST 102. And right now, there're NO LSx heads on earth that'll outflow the Mast offerings. So to benefit from the FAST102, you're gonna need an awfully big stroker with the Mast heads.
Old Mar 20, 2010 | 01:25 AM
last_'s Avatar
Car: 91 Camaro RS
Re: fuel injectors
roger that. so for now it will just look pretty sittin up there on top of the engine.
in the future tho, when i get some rockin afr's on there... maybe then i will see the potential of the fast intake.
as always, input is much appriciated!
Old Mar 20, 2010 | 07:10 AM
Klortho's Avatar
Car: 1987 GTA
Re: fuel injectors
What Atilla is trying to tell you is, MAST makes the biggest baddest heads for the LS series motors and didn't see any improvement with the FAST intake over the stock LS3 intake. The 102 is for people using big turbos so it will move the air through, he like myself and five7 don't want to see you waste money on something that's not needed in a N/A situation.
Old Mar 21, 2010 | 12:35 AM
last_'s Avatar
Car: 91 Camaro RS
Re: fuel injectors
Ah ha.. i see i see. already bought it a bit ago. so it will work when i get bored with the engine i am building now and decide to go for a turbo in a couple of years. >
bryan623
Mar 22, 2021 06:43 PM
New2Chevy
Oct 4, 2015 11:27 PM
sweet_87_iroc
Sep 25, 2015 10:01 PM
kyleb24
Aug 15, 2015 08:24 AM
Firechicken86
Aug 12, 2015 10:07 PM
