Whats the best lt1 headder
Old Apr 9, 2010 | 10:48 AM
MSRed91Camaro's Avatar
Car: I have a 91 Camaro RS
Engine: 383 stroker
Transmission: Stock automatic 700r4
Axle/Gears: I have 3.73 Gears with a Eaton posi
Im looking into installing an Lt1 into my car and I would like to know what is the best/most affordable headders and y-pipe for an Lt1 installed into my 91 camaro.
Old Apr 9, 2010 | 12:06 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
Best? PM TGO member Dyno Don, tell him what you're doing.
Most affordable? A set with matching y-pipe that is at least 1-5/8" primary, assuming you're talking about shorties. Most anything you get that's below $400 will need some sort of modification. If you want or would be interested in dual cats, the Hedman emissions-legal set for dual cats is pretty decent.
Can you weld? You might consider welding around the tubes on the outsides of the flanges to fill in the gaps around the tubes, then port matching the flanges on the head side.
Old Apr 13, 2010 | 11:16 AM
Engine: 383 stroker
Re: Whats the best lt1 headder
No unfortunatly I cant weld. So will any headder with a 1-5/8" primary, work with aany chevy 350 block?
Old Apr 13, 2010 | 11:53 AM
Klortho's Avatar
Car: 1987 GTA
Axle/Gears: 9 bolt 3.70 posi
https://www.thirdgen.org/forums/ltx-...aders-lt1.html
Old Apr 15, 2010 | 10:31 PM
Engine: 383 stroker
Cool, What if i dont go with an lt1 though, im also considering a carbed 350, will headders with a 1-5/8" primary still work... also if i switch over to a carbed engine I wont have to worry about o2 sensor ports or will I?
Old Apr 16, 2010 | 12:19 AM
1bdbrd's Avatar
Car: 1991 Trans Am
Do yourself a favor and go with 1 3/4 headers. There's no reason to limit your header size, within reason of course.
Old Apr 16, 2010 | 03:59 PM
Klortho's Avatar
Car: 1987 GTA
1 3/4 headers are a waste on an LT1, the stepping to the larger tube size has shown to actually rob power and the LT1s love the 1 5/8 tube for some reason.
Old Apr 17, 2010 | 03:24 AM
1bdbrd's Avatar
Car: 1991 Trans Am
I would like to see how more flow hurts power?
Old Apr 17, 2010 | 07:42 AM
Klortho's Avatar
Car: 1987 GTA
It's the way the exhaust exits out of the head and has to deal with the step which causes some swirling in the header.
Old Apr 19, 2010 | 10:08 AM
Engine: 383 stroker
Back to my question though what header should I use for a carbed 350, not an Lt1. Also will I have to worry about O2 sensors?
Old Apr 19, 2010 | 11:02 AM
Dyno Don's Avatar
Transmission: Tremec T-56
Axle/Gears: 12 Bolt 3.73
These:
Old Apr 19, 2010 | 11:10 PM
Engine: 383 stroker
What Type Are those Dyno Don... Ive herd that you make/sell sets of headders. About how much do they go for.
88SS6SPEED
Nov 11, 2015 07:05 AM
L0tuS
Oct 4, 2015 08:07 AM
WejaZ28
Oct 3, 2015 07:38 PM
CatmanFS
Sep 19, 2015 09:00 AM
L0tuS
Sep 4, 2015 11:16 PM
