Best Headers on LT1
Old Jun 30, 2005 | 01:25 AM
DF'sCamaro's Avatar
Car: 1992 RS Black
Engine: 305 TBI(LT1 swap soon)
Transmission: T5 (T56 for LT1 swap)
Axle/Gears: 4.10
Best Headers on LT1
I was wondering on what are the best Long tubes that are already coated that will bolt up to an LT1 and also have no emission stuff. I am going to do custom dual exhaust that going to be side swept right before the rear tire I seen it done before. So help me out on getting my long tubes. The headers have to fit a 3rd gen though I working on getting all the parts for my LT1 swap.
Old Jun 30, 2005 | 04:30 AM
Z28ricer's Avatar
Car: 93 240SX
Engine: LQ9
Axle/Gears: 3.54 R200 IRS
Since you want a longtube you have two brand choices, Hooker and Hedman.
The hookers are offered in 1.75" primaries, im very sure their ports will swallow the LT1's D ports, just like SLP's do. The main downside is they hang LOW LOW.
The hedmans have a 1 5/8 primary, tuck up a LOT better than hookers, which is why I am likely to be running them soon, my last setup had SLP's, and since they only offer them coated now, and their coating is junk, I wont buy from them again. Another upside to the Hedmans is their normal thirdgen longtube is pn 68460 and they offere p/n 68469 for D port heads, so you shouldnt have to worry about the 1 5/8 not fully covering the port.
Old Jun 30, 2005 | 09:26 AM
Klortho's Avatar
Car: 1987 GTA
Axle/Gears: 9 bolt 3.70 posi
I'm running the Hedman shorties on mine with the d-ports, only thing I had to do with them is drill the holes and weld the O2 bungs in the headers since LT1's have two instead of one like the 3rd gens do. 1 5/8 primaries to 3" collectors. I also got the y-pipe that bolts directly up to their headers as well, dumped it into a 3" i-pipe all the way to the muffler, but since you are going to go with custom duals that is moot anyway.
Old Jul 1, 2005 | 12:23 AM
DF'sCamaro's Avatar
Car: 1992 RS Black
Axle/Gears: 4.10
where would be the best place to buy a set of Hedmans?
Old Jul 5, 2005 | 08:18 AM
jagevileye21's Avatar
Car: 1991 Z28 Vert
Engine: LT1 350
Transmission: T56 6 Speed
Axle/Gears: 3.42 LSD
I have the hedman part #68460. I have been searching but I can't seem to find the y-pipe that fits into the headers. Anyone know where I can find it?
thanks a lot
JAG
Old Jul 5, 2005 | 08:40 AM
Klortho's Avatar
Car: 1987 GTA
For the long tubes you will probably have to have a custom y-pipe made, I'm running the 68479 which are the shorties and Hedman makes a y-pipe that is a direct bolt on to them.
Old Jul 5, 2005 | 09:57 AM
Car: 1991 Z28 Vert
Engine: LT1 350
I guess hedman does not make a Y-pipe to fit the 68460 headers.
Old Jul 5, 2005 | 02:54 PM
Car: 1991 Z28 Vert
Engine: LT1 350
anymore suggestions would be greatly appreciated
JAG
Old Jul 5, 2005 | 09:34 PM
DF'sCamaro's Avatar
Car: 1992 RS Black
Axle/Gears: 4.10
Run true duals by either dump it off a muffler of put a tips on it and angle it right before the rear tires.
Old Jul 6, 2005 | 08:47 AM
Klortho's Avatar
Car: 1987 GTA
Just run the Hedman LT's and have a custom y-pipe made up, or run the shorties and y-pipe and you can bolt up any aftermarket kit for the 3rd gens, just have to either put a cat on it or an off-road pipe in place of it like I did.
Old Jul 25, 2005 | 03:01 PM
BadIroc's Avatar
Car: 1988 Camaro IROC-Z
Engine: 350 Crate Motor Holley Stealth Ram
Transmission: WC T-5
Now why is there a huge price diffrence between the hooker long tubes apposed to the headmans? Is it because of t he size diffrence with the primaries with hooker being a 1 3/4 and headman being 1 5/8?? Just wondering because if it's cheaper for a reason then I don't want to bother. Plus anyone got any good pics??? My car is in the middle of an Lt1 swap so im shopping for headers...long tubes of course and they are going to be non emmision headers......b/c ummm ya i dont have any
Old May 31, 2008 | 08:50 PM
oxrabidus's Avatar
Car: 1989 Camaro RS
Engine: 2.8l v6
Transmission: 5 Speed Manual
Axle/Gears: Probably the stock 3.42
Re: Best Headers on LT1
I saw some Dynatech headers summit part DTC-114-831350...will these work with any problem on a third gen camaro? They say LT1/LS1, but i read on and they are for LT1 engines...will they work without any problem i am doing a LT1 swap myself and am looking for some headers...
Old Jun 1, 2008 | 07:12 PM
Klortho's Avatar
Car: 1987 GTA
No, those won't work due to them being for '93-97 F-body
Old Jun 1, 2008 | 09:17 PM
oxrabidus's Avatar
Car: 1989 Camaro RS
Engine: 2.8l v6
any particular reason? will they hit something? I also heard that a regular small block headers will work with an LT1, is this true?
Old Jun 1, 2008 | 09:36 PM
oxrabidus's Avatar
Car: 1989 Camaro RS
Engine: 2.8l v6
and how low do the hooker headers hang? if i was to lower my car an inch and a half or so would i have any problems?
Old Jun 1, 2008 | 09:37 PM
Klortho's Avatar
Car: 1987 GTA
If you go with the Hedmans with d-ports for angle plugs you won't be sorry for it, easier to change the plugs and from what I've read they tuck up under the car better than the hookers
Old Feb 28, 2010 | 02:30 AM
91camarosRS's Avatar
Car: 02wrx/88 rs
Engine: 2.0L turbo/nothing yet!
Transmission: 4eat/waiting on a t56
and what is that part number? i need hedders that tuck up for a lowered car and d port? for angled plugs?
Old Feb 28, 2010 | 10:55 PM
ssean92's Avatar
Car: sold
Headmen all the way. I have ran the shorties and LTs like both
Old Mar 1, 2010 | 12:25 AM
Car: 02wrx/88 rs
whats the part number?????
i want the part number for long tube headman headers d port with angled plugs? i wanna know how much and where to get headders for my lt1 swap. and im going to have a lowered car so i need clearance
i could use shorties but would rather have long tube.
Old Mar 1, 2010 | 06:27 AM
Klortho's Avatar
Car: 1987 GTA
PM sent, long tubes on a stock motor is a waste, just go with the shorties and you'll like it better. The shorties use the factory locations for the y-pipe, everything is tucked up and out of the way.
Looks like Hedman discontinued the d-port long tubes
Old Mar 1, 2010 | 10:58 AM
Car: 02wrx/88 rs
they discontinued????? no!
but its only going to be stock for a little while before i bore and stroke it, port heads im going to build it up to around 550flywheel. 450 wheel
Old Apr 13, 2010 | 09:23 AM
86TA4SALE's Avatar
Car: 1986 Trans Am
Engine: LG4 305 carb
Transmission: auto 700R4
Axle/Gears: 2.73 open
The Hedman shorties are PN 68479 with 1 5/8 in primary, 3 in collector and 1/4 in thickness
http://www.summitracing.com/parts/HED-68479/
The matching y-pipe is PN 17478. 2.5 inch inlet/outlet with a slip fit.
http://www.summitracing.com/parts/HED-17478/
I wish they had a 3 inch y-pipe like the hooker 2055s.
~Matt
Old May 23, 2010 | 10:18 PM
Car: 02wrx/88 rs
just an update i found and bought long tube d port headmans from summit. ill post some pics if wanted. however im not going to lie a little disapointed with the finish but i could get them coated for around 150
Old May 29, 2010 | 11:24 PM
Rich2279's Avatar
Car: '98 Mustang GT
Engine: '03 4.6L
Transmission: T45
Axle/Gears: DK
Yes, post some pics if you have them!
Old May 31, 2010 | 07:43 PM
Car: 02wrx/88 rs
im at work right now but will tomorrow. Anything special i should show?
Old May 31, 2010 | 10:28 PM
Rich2279's Avatar
Car: '98 Mustang GT
Engine: '03 4.6L
Transmission: T45
Axle/Gears: DK
If you could get a pic of the clearance between the header and k-member, that would be great. I read that the driver's side header has to have a dent put in the header tube in order for it to fit. Did you run into this problem? Any issues w/ these being installed on a manual trans car that you know of?
Old May 31, 2010 | 10:31 PM
Car: 02wrx/88 rs
well im sorry to report but its going to be awhile before i install them...
Old Jan 24, 2011 | 12:20 PM
dannyvera778's Avatar
Car: 91 camaro
Engine: LS3
i know this is old but having a hard time figuring out if 1 5/8 long tube headers are the right kind for my car? i thought that this will hinder your performance when you go above the 400 hp range? are the 1 3/4 the right one for people doing performance compared to leaving the lt1 stock?
TX-SleeperC5
Feb 24, 2016 01:34 PM
L0tuS
Oct 4, 2015 08:07 AM
jerflash
Sep 24, 2015 03:11 PM
mygta87
Sep 14, 2015 10:36 PM
L0tuS
Sep 4, 2015 11:16 PM
