ac hoses for ls1 swap
Old Apr 10, 2010 | 08:38 AM
oners2nv's Avatar
Car: 1992 Z28
Engine: Magnacharged heads cam lq4
Axle/Gears: strange s60 4.10
I got on hawks third gen and saw they had ac hoses for ls1 swap only if you had headers. I am running the stock manifolds. I wandered what you guys did for your hoses. I am using the ls1 compressor with everything else third gen.
Thanks.
Old Apr 11, 2010 | 12:09 PM
candy burple rs's Avatar
Car: 87coupe,91RS Camaro's, 00 Suburban
Engine: LSX427HO w/D-1SC and intercooler
Transmission: RPM Tremec T-56 Magnum
Axle/Gears: DTS 12bolt, 3.42
Re: ac hoses for ls1 swap
Hey bossman< got those lines you looked at on line and I'm using 06 vette compressor and a F-body ac bracket..on my Mastmotor sports LSX427 and Procharger(D-1)...
Started working on the ac today and lines look alittle long but will work..I'm using the third gen Accumulator and AC/Heater box with a little plastic missin.
I have custom headers 1 7/8 but I don't see why you would have any probs with stock..if time and figuring the pic thing on there I will try to send you pics.GOOOD LUCK
Old Apr 11, 2010 | 01:27 PM
oners2nv's Avatar
Car: 1992 Z28
On Hawks they have a pic of the lines with headers and it is wide open with lots of room. Then I went out and looked at mine with the manifolds and the egr port on the manifold looks like it might be in the way. I have some 01 manifolds that might help me with some more room.
1984HO
Mar 19, 2021 11:59 AM
smokingss
LSX and LTX Parts
Mar 3, 2016 07:40 PM
lt1z350
Brakes
Sep 12, 2015 09:28 PM
sreZ28
Aug 14, 2015 07:48 PM
reiderz iroc
Aug 13, 2015 04:57 PM
