Any aftermarket gauges that work with LS1 sending unit??
Car: 1986 Trans am
Engine: 5.3 LM7
Transmission: T56 6 speed
Axle/Gears: Dana 44 w/ 3.55's
Hey all. I'm putting an LS1 F-body tank and pump in my car and I am not using my factory gauges. Instead I'm retro fitting Autometer gauges into my dashboard, and I am just curious if autometer makes a gauge that has the compatible Ohms for the LS1 sending unit? I know stock is 0-90 and I believe the LS1 set up is something like 30-240??
Has anybody used an autometer or similiar gauge with the LS1 sending unit and had it work fine? If so, what should I look for?
Car: 89 Camaro RS
Engine: LM7
Re: Any aftermarket gauges that work with LS1 sending unit??
http://www.summitracing.com/parts/ATM-4316/ Should work with a 4th gen sending unit.
Car: 1986 Trans am
Engine: 5.3 LM7
Car: 89 Camaro RS
Engine: LM7
Not speaking from experience. I looked into doing a 4th gen tank swap but i ended up staying with my stock tank. You may want to look around on ls1tech to see what aftermarket gauges are being used on 98-02's. Here's a link to the 4th gen fuel system wiring that may help out.
http://lt1swap.com/pictures/7_fuel_tank.gif
Ghettobird52
Jul 5, 2024 11:18 PM
