Threads for steam pipe?
Old Apr 15, 2010 | 06:55 PM
SomeGuy25thZ's Avatar
Car: 1992 z28
Engine: 383 LT1 in the works
Transmission: T-56 in the works
Axle/Gears: 3.73 in the works
Anyone know what fittings are used for the steam pipe at the back of the LT1 heads? I dont want to run the factory steam pipe setup and instead I want to run stainless hardlines but dont know which fittings to use.
I am thinking head head has one (1/4" ??) line that goes into some kind of connector or T that then goes where ever it needs to go. Any suggestions?
If someone has done something like this before, please let me know what worked for you.
Old Apr 15, 2010 | 07:52 PM
Pocket's Avatar
Car: 91 Trans Am
Re: Threads for steam pipe?
The stock bolts are more banjo fittings than bolts. You wont find these in any store and would have to be machined
Old Apr 16, 2010 | 08:43 AM
Firebat's Avatar
I'm trying to find what I saw a while back. Yes, you can make something custom up using some kind of T-fitting. I remember what a pain and how stupid that crossover tube and banjo bolts setup was when I had to re-install it, definitely going to make a custom line instead the next time I have to re-install the heads.
I found something but not what I remember looking at:
http://www.ls1tech.com/forums/lt1-lt...ack-heads.html
http://www.ls1tech.com/forums/lt1-lt...tube-back.html
Linson
Sep 21, 2015 01:08 PM
Stroopwafel
Sep 11, 2015 06:38 AM
Nick McCardle
Sep 10, 2015 08:36 PM
89fast5oh
Sep 8, 2015 09:55 AM
