How to wire 88-92 firebird gauges directly
Old Apr 15, 2010 | 07:39 PM
Aaron91RS's Avatar
Car: RS
Axle/Gears: 9" for the ladies
Help me get some good info in this thread. Instead of wiring in to were we are for the guages can we wire directly to the back of the guage without the circuit board. I don't see why not, so help me line out what goes where.
In the pic is the tach(left when looking at the pic) speedometer on the right.
Each has 3 connections. I labeled what the circuit board is printed with, with the same letters in red.
E is ground
IG is power
- is the tach wire.
S is VSS
http://img691.imageshack.us/img691/449/imgp4070a.jpg
To break out both plugs
From a 1991 firebird service manual,
connector C2 (upper connector)
1 brake warning indicator, tan/white
2 ground, black
3 instrument cluster illumination, gray
4 n/a
5 n/a
6 n/a
7 LH turn indicator, light blue
8 hi beam indicator, light green
9 RH turn indicator, dk blue
10 fuel gage output to sender, purple
11 supplemental inflatable restraint (air bag), brown
12 n/a
13 service engine soon light, brown/white
14 shift indicator, tan/black
connector C1 (lower connector)
1 tachometer , white wire
2 ground from hi beam LH turn RH turn and cluster, black
3 cluster illumination, gray
4 security indicator, gray
5 coolant temp gage output, dk green
6 n/a
7 n/a
8 oil pressure gage output to fuel pump/oil pressure sender, tan
9 ignition power from gage fuse, pink/black
10 n/a
11 n/a
12 ground from seat belt indicator/voltmeter, black
13 seat belt indicator, yellow
14 vehicle speed signal, gray (except vin E, tan)
Attached Thumbnails How to wire 88-92 firebird gauges directly-imgp4070a.jpg
Old Aug 17, 2012 | 05:07 AM
firechicken1992's Avatar
Car: 92 Firebird--02 Grand Prix GTP 2Dr
Engine: Poncho 400--3.8 Supercharged
Transmission: T56 6 Speed--4T65EHD
Axle/Gears: Open 10 bolt 3.42--Internal 2.93
Re: How to wire 88-92 firebird gauges directly
did you ever figure this out? ive been wondering the EXACT same thing with my project
Old Aug 17, 2012 | 11:37 AM
86White_T/A305's Avatar
Car: 1987 TransAm Ttop
Engine: 2005 LQ4
Transmission: Ls1 T56
Axle/Gears: 3:54
What is there to gain by going directly on the cluster board itself? I made my gauge connections at the connector where the cluster plugs into.Didnt mess with the cluster at all and I can always put it back to factory.I have a few clusters and have swapped them in and out within mins.
BRoss99
Aug 10, 2025 05:08 PM
rocn7roc
Sep 21, 2021 02:16 PM
toronto formula
Nov 10, 2015 06:17 AM
355sbcTPI
Aug 19, 2015 04:38 PM
Jk_Under
Aug 17, 2015 03:08 PM
