v6 to lt1, speedo / Engine braking
Old Apr 16, 2010 | 12:46 AM
kukerdan's Avatar
Hey guys...
I switched the tailshaft housing and plastic speedo gear from the v6 4l60 to the lt1 4l60e.... But since the lt1 was supposed to have electric vss, and that also enables engine braking... what do I do?
I want my stock gauges to work, i dont want to spend money on something i dont need.. like newer or custom gauges...
do i need engine braking? im sure my camaro didnt have a decel fuel cutoff before, i could see it being handy tho in a hard decel situation...
is there a workaround to have both?
thanks
Old Apr 16, 2010 | 01:06 AM
five7kid's Avatar
Transmission: 4L80E/4L80E
Sounds like you need something like this:
http://www.summitracing.com/parts/SUM-G2887-1/
Old Apr 16, 2010 | 10:56 AM
Pocket's Avatar
Car: 91 Trans Am
Re: v6 to lt1, speedo / Engine braking
Yup, or use the electric VSS from the new trans to power a cable driver box
Old Apr 23, 2010 | 08:48 PM
Firebat's Avatar
You're going to need a different gauge for the RPM anyway since had a V6, why not just replace all gauges with ones from a V8 91-92 camaro with the electric speedo? Think it would be not much price difference between those and a cable converter box. Might be cheaper.
Old Apr 27, 2010 | 12:02 PM
kukerdan's Avatar
Hey guys here is my dilemma....
I CUT the old speedo gear off of the lt1 4l603, and put the plastic one from the v6 700R4 in place... Now I find out that the LT1 computer needs this speedo gear for other things, like fuel tables, engine braking (which i could do without) and to SHIFT!
I thought it could shift without knowing the speed... isnt rpm sufficiant? Why cant I just delete this out of the LT1 computer???
Whats my cheapest way out?
Old Apr 27, 2010 | 04:27 PM
Pocket's Avatar
Car: 91 Trans Am
Find another 4L60E in a JY then pull the reluctor ring and VSS to install back in there
The PCM output wire will drive a cable box so your mech speedo will function
Old Apr 27, 2010 | 05:11 PM
kukerdan's Avatar
i just cut the ring off, i still have the vss, so i can just get a new ring , would they have it at an auto parts store? or do i need to ebay / junkyard it
midge54
Dec 27, 2019 04:14 PM
Azrael91966669
25
Jun 20, 2017 04:04 AM
Eagle223usa
Brakes
Aug 14, 2015 09:24 AM
bradleydeanuhl
Aug 12, 2015 11:48 AM
1992 Trans Am
Aug 8, 2015 08:16 PM
