LSX and the short vs long crank
Old Apr 27, 2010 | 07:18 AM
88 350 tpi formula's Avatar
Car: 89 FORMULA 350, 91 Z28 Convertible
Engine: ls1, LB9
Transmission: t56, Auto
Axle/Gears: S60/ 3.73
OK, I think most of us here know there are two differant cranks in the early LSX motors (manual, auto) so if you buy a early 5.3 or similar eng. mostlikely its from an auto trans.... it has the short crank.. but, you plan to mate it with a manual so you need to buy the spacer and all is set. your ready to go!
now my question is arent all the "LS1" eng from corvettes,f-bodies and so on short cranks? some have a t56 others have the 4l60e ?? why dont these use differant depth cranks?
Old Apr 27, 2010 | 07:56 AM
five7kid's Avatar
Transmission: 4L80E/4L80E
The early truck engines had the long crank, from what I understand.
Not sure why they had different length cranks. Perhaps something to do with truck vs. passenger car transmissions. By 2000 or 2001, they were all the short type.
Old Apr 27, 2010 | 05:38 PM
Pocket's Avatar
Car: 91 Trans Am
Re: LSX and the short vs long crank
They changed the flange length only with the 6.0Ls because they were the only engines that could be had with the 4L80E trans. The 4L80E trans is a conventional design, with the bellhousing boltpattern changed to the new LSx style
Later, GM introduced the spacer design to cut production costs. Same crank fits all 5.3, 5.7, 6.0's and utilizes a separate converter snub adapter to receive the traditional style 4L80E TC. This is a blessing to swappers who want to use an older trans. Otherwise they'd need a custom TC or to swap the 99-00 6.0L crank in
Old Apr 27, 2010 | 08:38 PM
BlueZee28's Avatar
Engine: Cammed 6.0L LSX
Jon beat me to it. What he said ^^^
Old Apr 27, 2010 | 09:26 PM
Engine: ls1, LB9
ok, I like the responces... it what I came to as well.. thanks guys! maybe someone in a search will find this header and look in
anesthes
Mar 10, 2016 10:35 PM
Fox118
Members Firebirds
111
Jan 26, 2016 07:17 PM
gixxer92
Sep 1, 2015 04:32 PM
TheExaminer
Aug 26, 2015 04:59 PM
Winchester1094
Aug 18, 2015 10:23 AM
