4th gen clutch pedals w/ ls1 swap?
Car: 1992 Z28 Heritage Edition
Axle/Gears: 3.23:1
I am curious for those that are swapping LS1/T56 combos in their cars... What pedal assemblies are you using? I can't seem to find any 3rdgen pedal assemblies that aren't totally rusted. Has anyone modified a 4thgen pedal assembly to fit? Was it worth it?
Transmission: 4L80E/4L80E
It's been covered by several different members. Here's mine: https://www.thirdgen.org/forums/ltx-...h-gen-t56.html
Car: 86 Trans AM
Engine: LS1 (not stock...)
Transmission: Built T56
Axle/Gears: Strange 12-bolt w/ 3.73
Re: 4th gen clutch pedals w/ ls1 swap?
Dante, as five7 said, its been covered a bunch of times. There are even dedicated threads that are pretty recent in the swap forum. Do some searching...but the bottom line is you can use either set, but they'll both require some modification to fit 100%.
J.
J.
Car: 1989 IROC-Z, 1979 Malibu Classic
Engine: LSx 5.3
Transmission: MN12 6-speed, 4L60E
Axle/Gears: 4th gen 3.42
4th gen pedals and adjustable clutch master cylinder work perfect for mine.
Denricci22
Sep 18, 2015 09:02 AM
