1999 Silverado 5.3 to 1991 Camaro rs
Old May 22, 2010 | 08:31 AM
Willie B.'s Avatar
Car: 91camaro
Engine: 5.3
Ok well i finally picked up my 5.3 engine the other day. But what I need to know is if the engine still has the wiring harness with it do need to splice into the original TBI wiring harnesss. I know i need to for the starting and charging system, but I was thinking as far as managing the engine just install the truck ECU for the engine and use manuel gauages for temp, oil pressure, etc. What is the absolute best way to approach the the wiring?
Old May 22, 2010 | 08:37 AM
Atilla the Fun's Avatar
On Probation
Engine: several
Transmission: none
Axle/Gears: none
Re: 1999 Silverado 5.3 to 1991 Camaro rs
I'd bet Pocket is the guy to ask. He'll probably even answer today or Monday.
Old May 22, 2010 | 12:10 PM
Pocket's Avatar
Car: 91 Trans Am
https://www.thirdgen.org/forums/post...009-post4.html
What year is the 5.3 and PCM. The above uses the super common 99-02 Fbody pinout and diagrams. GEN IV truck engines and DBW only PCMs throw a wrench into the procedure but its still similar
Old May 23, 2010 | 09:30 PM
Willie B.'s Avatar
Car: 91camaro
Engine: 5.3
The pcm of the truck is a 99 and the engine as well. I have started with the wiring harness according to the links today. I cut out all thw commons and the 207. What is different with the trucks harness from the f bodies?
Old May 23, 2010 | 09:32 PM
Willie B.'s Avatar
Car: 91camaro
Engine: 5.3
Oh and I see your in NC in you don't mind answering what part?
Old May 23, 2010 | 10:38 PM
Pocket's Avatar
Car: 91 Trans Am
Winston
Top of the list difference for car/truck is the injector connectors
Old May 27, 2010 | 08:39 PM
Willie B.'s Avatar
Car: 91camaro
Engine: 5.3
Thanks pocket for the info dont know what i would have did without it..
xkingcodex
Feb 12, 2020 07:43 PM
sailtexas186548
Exterior Parts for Sale
Feb 29, 2016 08:40 AM
E Rod
Aug 28, 2015 05:17 AM
Zachattack0925
Aug 12, 2015 09:54 PM
Zachattack0925
Aug 12, 2015 09:52 PM
