Fuel Pressure regulator mount for ls1 swap?
Old May 27, 2010 | 09:58 AM
Roachjr's Avatar
How did you guys that have done this swap mount your pressure regulator? If anyones got some detailed pictures that would be great. Thanks
Old May 27, 2010 | 10:40 AM
1ADan's Avatar
Car: 1987 Trans Am
Engine: LQ9/L92
Re: Fuel Pressure regulator mount for ls1 swap?
if you go with the corvette filter/reg piece, you can put the new piece where the stock fuel filter is. no pics yet, but i'm copying that route from a few other members here
Old May 27, 2010 | 03:41 PM
Roachjr's Avatar
Well I've already got a regulator from Hawks. Just need to see how everyone has made a bracket for it, and where the bracket is mounted.
Old May 27, 2010 | 04:01 PM
Shift06's Avatar
Car: 1991 Trans Am GTA
Engine: LSX (swapping)
Transmission: 4L60E (swapping)
Axle/Gears: 2.73 Posi 10 Bolt
I have the same problem you do, I plan on mounting it to the drivers side fenderwell but havent made up a bracket yet.
Old May 27, 2010 | 05:51 PM
$750 L98's Avatar
Car: 1989 Formula 350 LSX
Engine: 5.3, 234/228 cam
Transmission: Stage II 4L60e, Vigilante 3200
You could also use the older style corvette fuel rails with a return line, makes it much easier to hook up the stock stuff and a LS1 tank.
MustangBeater20
Oct 29, 2022 09:20 PM
9192camaro
16
Feb 3, 2019 12:21 AM
wayshegoes
Aug 17, 2015 12:00 PM
89-S-dime
Aug 12, 2015 11:57 AM
Kaweh
Aug 9, 2015 02:54 PM
