ls1 harness
Old May 27, 2010 | 05:01 PM
RockJay81's Avatar
Car: 84 Z28......99 TA
Engine: Lq9 6.0... Ls1
Transmission: 4L60E X's 2
Axle/Gears: 3.73 on both
ls1 harness
anyone know wtf is the MIL wires are. one is black with ground and the other is red with power when the engine is cranking. the engine cranks and only stays on with the key still on the starter engaged position. i reflashed the ecu and deleted the vats
Old May 30, 2010 | 10:47 PM
Pocket's Avatar
Car: 91 Trans Am
Re: ls1 harness
MIL stand for malfunction indicator lamp. Its your check engine light
There should only be one wire to mess with from the PCM. Your stock cluster draws fused 12v IGN from the fuseblock to the light, then when a trouble code is stored, the PCM grounds the circuit illuminating the bulb. Sounds harder than it really is
Just connect the PCM MIL wire to C207 pin C. Its the same pin from 82-92
Old Jun 2, 2010 | 08:13 AM
RockJay81's Avatar
Re: ls1 harness
thanks bro i got her to run finally but the fuel pump gets hot and cuts out i guess i mounted her too far from the tank. its on the outside of the frame in the front of the car. im broke now so i have to wait till next check to get the tools to mount it in the rear.
Old Jun 2, 2010 | 08:27 PM
Pocket's Avatar
Car: 91 Trans Am
Re: ls1 harness
Sounds like a restriction in the line
Is there a pump in the tank still or possibly fuel filter on backwards?
Old Jun 2, 2010 | 08:37 PM
RockJay81's Avatar
Re: ls1 harness
its a walbro 255 external pump. i have the corvette filter with the return on it. i set the filter up the same way you did on your thread. i am going to mount the pump closer to the tank. a friend told me pumps push better than they pull fuel. hopefully it works i'll let you know what i find out next week. im totally broke now gotta wait till next pay check lol
8889gtaformula
Exterior Parts Wanted
Nov 5, 2015 04:17 AM
dbrochard
Sep 19, 2015 08:13 PM
gczj13
Sep 18, 2015 01:09 PM
timonator
Sep 17, 2015 06:57 PM
Billy Decker
Sep 4, 2015 03:46 PM
