Ls1 t56 swap problems
Old Jun 8, 2010 | 05:55 PM
mike82337's Avatar
Car: 1989 trans am gta
Engine: 99 ls1 383
Transmission: t56
Axle/Gears: stock 9 bolt 327
Hey guys, lookin for a little help, I just got my swap up and running in my 89 gta and the car fires right up and idles mint itl even rev up fine. But as soon as you drive it and put it under a load itl start breaking up badd. I checked it with a tech 2 and it seems to be going way lean like in the double didgets when I get the problem. The car literally falls flat on it's face. I only have long tubes with turndowns right now and a couple ppl have been suggesting back pressure problems because of the lack of exhaust but to me it feels like some kind of sensor issue. I'm going to finish the exhaust hopefully this weekend just to rule that out, but has anyone had a similar problem or any ideas?
Thanks,
mike
Old Jun 8, 2010 | 06:48 PM
kizmaro89's Avatar
Car: 89 Camaro RS
Engine: LM7
Re: Ls1 t56 swap problems
Low fuel pressure maybe?
Old Jun 8, 2010 | 09:38 PM
Spike-Z's Avatar
Car: IROC-Z
Engine: LSx
Axle/Gears: Fabbed 9"
You wouldnt have a wait4me tuned pcm would you?
Old Jun 9, 2010 | 07:52 AM
mike82337's Avatar
Engine: 99 ls1 383
Transmission: t56
I got about 58-60 psi even when it dies out. And I re routed the fuel line away from the headers just to rule out any kind of vapor lock problems.
Old Jun 9, 2010 | 07:54 AM
mike82337's Avatar
Engine: 99 ls1 383
Transmission: t56
The PCM hasn't been tuned yet, it's mostly stock aside from
the normal removals like egr and air pump etc, it's just got the long
tubes performance wise
Old Jun 9, 2010 | 01:41 PM
techrunner's Avatar
Car: 91 Formula
Engine: lq4
Transmission: t-56
i'm not an expert, but it does sound like a fuel issue. checked the injectors? i have heard of them sticking. maybe a seafoam soak for the injectors if they are gummy. dunno, just thinkin out loud.
Old Jun 9, 2010 | 02:29 PM
mike82337's Avatar
Engine: 99 ls1 383
Transmission: t56
Definately appretiate the thoughts, I haven't tried playin with the injectors yet but I feel like that would show itself more at top end as well and if you let off and floor it when it starts breaking up itl climb out of
it and pull hard to the top.
Old Jun 9, 2010 | 02:58 PM
DIRTY JERZY's Avatar
Car: 89 formula 350 & 2001 ws6 ta
Engine: 350 tpi & ls1
Transmission: 700r4, t56
Axle/Gears: 9 bolt ? & 10 bolt 3:42
maf of sd tune?
Old Jun 9, 2010 | 08:14 PM
Spike-Z's Avatar
Car: IROC-Z
Engine: LSx
Check out this thread: http://www.ls1tech.com/forums/genera...situation.html
I had a similar situation with mine. turned out to be the pcm.
Old Jun 10, 2010 | 09:13 AM
mike82337's Avatar
Engine: 99 ls1 383
Transmission: t56
Spike, thanks for that thread I'm considering the PCM now because I also don't have any codes for this problem, I haven't tried unplugging the coils yet but il try that today. Also I think I'm gonna scope around for a vacuum leak just to rule it out. Thanks again for all the ideas guys
Old Jun 10, 2010 | 11:04 AM
Jaysz28's Avatar
Car: 91 Firebird
Engine: 6.0
I had that issue, but my turned out to be a FP issue
The rubber hose in the tank burst on me.... lol
that was a fun one to track down
1984HO
Mar 19, 2021 11:59 AM
sreZ28
Aug 14, 2015 07:48 PM
reiderz iroc
Aug 13, 2015 04:57 PM
hokis
Aug 9, 2015 03:57 PM
1992 Trans Am
Aug 8, 2015 08:16 PM
