lt1 distributor questions
Old Jun 15, 2010 | 01:21 PM
BiggTrav's Avatar
Car: 92 zo3 z28
Engine: LT1 w/lt4 hotcam kit
Transmission: stage 3 700r4
Axle/Gears: posi 3.42
i have a 93 lt1 in my camaro and im converting it to a 96 MAF system. what im wondering is do i have to change distributors or will the 93 work with the 96
Old Jun 15, 2010 | 01:46 PM
92RSMoneypit's Avatar
Car: 92 camaro B4C
Transmission: t5
Re: lt1 distributor questions
Your going from speed density to MAF The only difference is the way they mount up and one is vented and ones not changing to a 96 distributor is a big job including other parts plus the distributor.
Old Jun 15, 2010 | 03:50 PM
Pocket's Avatar
Car: 91 Trans Am
The small extension harness changes between the different optis, but the connector going to the engine harness is the same, so in short no, you dont have to change the opti
Swapping the newer opti onto the 93 will require the newer timing cover and small extension harness. I wouldnt bother unless you absolutely have to, the balancer hub is a bear to remove/install
Old Jun 15, 2010 | 07:01 PM
Klortho's Avatar
Car: 1987 GTA
Axle/Gears: 9 bolt 3.70 posi
Also don't forget that the '93 is splined and the '95+ is pin driven, the cam has a bigger hole in the end for the opti to go into and find a way to pull the pin in the cam out to drive it.
Frozer!!!
Jan 19, 2024 04:55 PM
midge54
Jan 29, 2017 07:00 PM
Caspar
Jun 19, 2016 11:19 PM
86IROC112
Aug 17, 2015 07:57 PM
redmaroz
Aug 16, 2015 11:40 PM
