torque arm wondering..w/the lsx
Old Jul 3, 2010 | 10:37 AM
candy burple rs's Avatar
Car: 87coupe,91RS Camaro's, 00 Suburban
Engine: LSX427HO w/D-1SC and intercooler
Transmission: RPM Tremec T-56 Magnum
Axle/Gears: DTS 12bolt, 3.42
Well Happy 4th, hope you'll can help.
91 camaro had installed in it the BMR track/off road torque arm set-up
by a buddy and me when I had the Ramjet 350 in the car with a Rich. 6spd.
We used the 2.5 inch stock driveshaft and the 30 spline yoke for the 6spd.
Now the LSX came along and I ordered a 3.5 alum. shaft and it didn't fit so I
got 3in molly shaft. It fits like the aluminum one but hits the same on the
torque arm. With the BMR plate for the arm that attaches to the rear, it had
2 sets of bolt holes to bring the arm closer to the driveshaft or keep it about
an inch away. Reason moved it closer to the rear pumkin because it
was hitting the tunnel. SO has anybody used this set-up and not cut the
bracket down, and did it give to the alotted clearance you were looking for
with a bigger driveshaft. Hawk said he used the same torque arm and fit a
3in shaft in the same area. But its a holiday and have only you'll to ask..I will
take pics if can....I just want to confirm this bracket deal before I purchase..tks
Nervous2
Oct 8, 2015 10:53 PM
luvofjah
Sep 26, 2015 08:28 PM
89newfun
Sep 16, 2015 09:28 AM
Ragtop Man
Sep 12, 2015 12:23 AM
