LT1 knock sensor(s)?
Old Jul 10, 2010 | 01:17 PM
SomeGuy25thZ's Avatar
Car: 1992 z28
Engine: 383 LT1 in the works
Transmission: T-56 in the works
Axle/Gears: 3.73 in the works
is there one knock module or two knock modules for LT1 engines?
I have a corvette stand along LT1 harness and it has two knock sensor connectors. One goes on each side o the block just above the oil pan correct? I currently have NPT plugs in each hole... if i take the plugs out will oil spill out? Engine is full with break-in oil.
Old Jul 10, 2010 | 02:50 PM
Klortho's Avatar
Car: 1987 GTA
Axle/Gears: 9 bolt 3.70 posi
Re: LT1 knock sensor(s)?
Those plugs will empty the water jacket on each side of the engine. My LT1 only has one knock sensor
Old Jul 10, 2010 | 09:40 PM
adamwbennett's Avatar
The B body cars had two knock sensors and the fbody cars had one knock sensor. As said above it will empty the water in the motor out onto you as soon as you open them.
Old Jul 12, 2010 | 07:43 AM
Car: 1992 z28
OK, I have no coolant in the engine yet so I should be good then. I guess since my harness has the two sensor connections I should hook them both up and dont see what problems i would run into?
Old Jul 12, 2010 | 08:31 AM
Pocket's Avatar
Car: 91 Trans Am
The sensor wires tee together and go to one pin on the PCM. Use one or two, up to you. Two increases costs and complexity of the system
Id stick with one on the drivers side. Pass side knocks usually interfere with SBC LT headers
Old Jul 12, 2010 | 08:47 AM
Car: 1992 z28
it is very close to my headers... thanks pocket. I'll just use the one on the drivers then and tie up the other and tuck it away or maybe just remove it all together.
L0tuS
Oct 4, 2015 08:07 AM
FormulasOnly
Sep 10, 2015 09:07 PM
MSgt Luttrell
Sep 5, 2015 11:28 AM
L0tuS
Sep 4, 2015 11:16 PM
tgp1990
Sep 4, 2015 06:24 AM
