Oil pan replacment
Old Jul 11, 2010 | 02:40 AM
ShMaCk2004's Avatar
Car: 1987 Camaro IROC-Z
Transmission: LS1 T56
Axle/Gears: Richmond 3.73
Oil pan replacment
So i ordered a new LS1 oil pan from GM to replace my broken one. I'll document how I go about doing it here when it comes in. Any advice as far as doing it goes? Right now I'm planning to support the engine up and drop the k-member.
Old Jul 12, 2010 | 08:30 AM
Pocket's Avatar
Car: 91 Trans Am
Re: Oil pan replacment
Dont pull the front springs unless you have to. They are a royal PITA, I did them a few days ago. Wrap a strap around the K and arms to keep them from opening and drop the unit as a whole
If you oil pump or pickup tube has ever been messed, with Id suggest pulling the pickup tube and inspecting the O-ring. May be fine, may be pinched and still showing good oil pressure. Mine was
Old Jul 12, 2010 | 09:09 AM
techrunner's Avatar
Car: 91 Formula
Engine: lq4
Transmission: t-56
so you can really just leave the k member assembled and drop the whole thing? would you just have to remove the 6 k member bolts and the motor mounts, and the steering shaft then? i might have to try that then. i'm kinda in the same situation, and i am dreading the oil pan swap. maybe it wouldn't be as bad then as i thought.
Old Jul 12, 2010 | 09:23 AM
Pocket's Avatar
Car: 91 Trans Am
Steering shaft is out of the way
Old Jul 12, 2010 | 10:44 AM
ghettocruiser's Avatar
Car: 86 Trans AM
Engine: LS1 (not stock...)
Transmission: Built T56
Axle/Gears: Strange 12-bolt w/ 3.73
You have to be VERY VERY careful dropping the k-member with the springs and arms still attached. Ive never done it this way, but Ive been trying to figure out a safe way to do it. Either way, its a cumbersome task to leave it all attached just due to the weight of the struts and spindles and all.
If you can figure out a safe way to do it, dropping it all together would be a great way. I fyou have lowering springs, removing/replacing the springs is really easy. Stock springs...its a PITA as pocket said.
Whatever you do dont just remove the 6 k-member bolts. That would get ugly in a hurry. Also dont forget to remove your calipers, and keep them tied up a nd away.
You might have to disconnect the brake lines if they are routed in such a way that the k-member wants to snag on them. Depends on what all you have done to the car. I bent my brake lines so that they can stay up on the car with the k-member gone.
J.
You guys have seen these pics...but this is how I do it.
Navy8125
Aug 21, 2015 09:32 AM
MY87LT
Aug 17, 2015 08:43 AM
matthew911
Aug 12, 2015 09:38 AM
89mulletbird
Southern California Area
Aug 10, 2015 10:16 AM
gwade12
Aug 8, 2015 08:17 AM
