Build Thread - 85 IROC 402 LS3 6 speed
Old Nov 24, 2010 | 07:44 AM
  #101
Jim85IROC's Avatar
Car: 85 IROC-Z / 88 GTA
Axle/Gears: 3.42 / ?
Re: Build Thread - 85 IROC 402 LS3 6 speed
Minor update: Last night I cut a couple grooves into one of my old cylinder head bolts and used it to clean the head bolt threads. After I finished that, I started to install the wrist pin retainers into the pistons. This is the first time I've had the pleasure of using these things... man, what a pain in the ***. I've got 2 pistons done so far.
I also discovered that I made a mistake when I was tightening my main cap bolts. I tightened to 15 ftlbs, then another 80* of rotation for both sets of bolts. I see now that the outer set should only be torqued 51 degrees. Good thing I used the old bolts for mock-up!
Old Nov 24, 2010 | 12:35 PM
  #102
five7kid's Avatar
Transmission: 4L80E/4L80E
Hey, a fellow shade-treer!
Old Nov 25, 2010 | 12:03 PM
  #103
Jim85IROC's Avatar
Yeah, when I saw what it was going to cost me for a single thread chaser in that goofy M11 size, I had to come up with a different plan. Somebody on 'tech suggested this, and it worked beautifully.
Old Nov 25, 2010 | 04:28 PM
  #104
one92rs's Avatar
Car: SOLD!!!!!
it does work well. i would also put a piece of hose on my air gun and stick it down in the holes to blow them out.
Old Nov 30, 2010 | 07:08 AM
  #105
Jim85IROC's Avatar
Last night I installed the wrist pin retainers on the remaining 6 pistons. On the first piston I did last week, it took me 20 minutes or more to install the two retainers. On the last piston, I think it took me 20 seconds.
By the time I got to piston number 6, I wasn't even using a tool anymore, I just did it completely by hand. It's funny how you get good at these things just as you're finishing up.
Tonight I'm hoping to have Dad come up so he can hold the crank while I clean it up, then I can do my final assembly on the short block.
Old Dec 1, 2010 | 07:52 AM
  #106
Jim85IROC's Avatar
Last night I cleaned the block and crank, slapped a pile of assembly lube onto the bearings and journals, and installed the main caps, hopefully for the last time.
one frustrating thing that I ran into is my crank endplay... again. I had .004" when I installed with oil, but now with the assembly lube, I can barely get .002" when I reef on it with a screwdriver. Same bearings, same everything. The crank spins freely (or as freely as it can spin now that it's in a bath of assembly lube).
Has anybody else had a similar situation, where the liberal use of assembly lube prevented an accurate endplay measurement?
Old Dec 9, 2010 | 05:47 PM
  #107
khulsebus's Avatar
Car: '89 Camaro
Transmission: 4L65/70E
Axle/Gears: 9 Inch, 3.70 gears
subscribed
Old Dec 9, 2010 | 08:47 PM
  #108
scooter's Avatar
Car: 92 Firebird
Engine: 4.8 LR4
Axle/Gears: 3.45 9 Bolt
Originally Posted by khulsebus
subscribed
WHYYYYYYYYYYYYYY!!!!!!!!!!!!!!!!! You dont have to say "subscribed" just subscribe to it. AT the top of the thread!
Old Dec 9, 2010 | 08:54 PM
  #109
mw66nova's Avatar
Car: camaro sportcoupe
Engine: 7.0L
Transmission: G-Force GF5R
Axle/Gears: Moser 9"
subscribed
sometimes saying "subscribed" lets the OP know to continue his documentation and lets him know that what he's doing is interesting and worth reading.
Old Dec 9, 2010 | 09:06 PM
  #110
scooter's Avatar
Car: 92 Firebird
Engine: 4.8 LR4
Looks good, keep it up, nice, any updates?
Jim I have been following this thread for a while now without being and idiot responder. Do you have any experience in building an engine before this? I am debating rebuilding the BBC in my 73 or buying another and doing that one
Old Dec 9, 2010 | 09:23 PM
  #111
last_'s Avatar
Car: 91 Camaro RS
Axle/Gears: stock...
for sure... made me laugh pretty hard just then.
Old Dec 9, 2010 | 11:54 PM
  #112
White'89's Avatar
Car: '89 GTA
Engine: 5.7L LS1
Axle/Gears: 9 bolt 3.27
I'll have to say subscribed to this as well. Some incredible attention to detail with very few "aw screw its". As long as you get those valve springs to come out right you should be able to rev the crap outta this thing.
Old Dec 13, 2010 | 08:02 AM
  #113
Jim85IROC's Avatar
I built one motor before this... it was the 350 that's currently in the IROC. My father and I built it in the mid 90s, shortly before I bought the IROC.
The valve springs are fine. Once I got rid of the Patriots and bought the PRCs, they measured right at their advertised height, which leaves me ample clearance for the cam I plan to run.
By the way guys, no progress lately. Been busy with other crap. I hope that tomorrow I'll get time to pull the crank out yet again so I can wipe off the assembly lube and re-convince myself that I have the endplay clearance that I need.
Old Dec 15, 2010 | 07:58 AM
  #114
Jim85IROC's Avatar
Last night I pulled the main caps back off the block. After I did, the crank had about 4 to 4.5 thousands of endplay. I re-assembled the main caps, this time smacking the crank back and forth with just the #3 cap in place (and tightened to less than the 15ftlbs it was tightened to last time), and things seemed to go much better. After fully torquing all of the caps, I still had my 4 thousands of endplay.
I'm much happier now.
Old Dec 15, 2010 | 10:46 AM
  #115
mw66nova's Avatar
Engine: 7.0L
hey jim, is there any clearancing needed for the longer stroke like in a genI stroker? what about small base circle camshaft and stuff?
Old Dec 15, 2010 | 11:03 AM
  #116
Jim85IROC's Avatar
No clearancing at all... the rod bolts are at least 1/4" to 3/8" away from the cylinder bores. No idea about the cam, but I don't expect any issues there either.
Old Dec 15, 2010 | 12:24 PM
  #117
mw66nova's Avatar
Engine: 7.0L
man that's great news...i'm thinking of building something bigger soonish
Old May 2, 2011 | 11:52 PM
  #118
Yahtzee's Avatar
Car: 1989 IROC-Z28 Camaro
Engine: 403 LSX
Transmission: TH400
Axle/Gears: Moser 9" 3.25's
Damn it's been awhile. updates?
Old Jul 29, 2011 | 02:10 PM
  #119
Jim85IROC's Avatar
Nope. Life is getting in the way. Once it turned cold I stopped working in the garage for the winter, and then in March I started a speaker project that won't go away... those still aren't done, and now I'm knee deep in a summer-long bathroom remodel project.
Finding time to work on this motor is hopeless. Plus, I still haven't found anybody to buy my C4 for 1/2 of book value, so I still don't have any money for a trans & rear end, so my motivation to finish the motor isn't exactly all that high.
But... next weekend my buddy is coming to town, and we always enjoy turning wrenches together, so I'm planning to finally pull the plastic off the motor and work on it some more. Hoping to get the pistons & rods into the block. Then I'll basically just be a camshaft shy of being able to finish the long block.
Old Aug 8, 2011 | 08:34 PM
  #120
Jim85IROC's Avatar
Well, this weekend we put the rings on the pistons and dropped the rods & pistons into the block. I ran into some concern when measuring the rod bolt stretch. The card that came with the rods specified .005" of stretch, or 75 ft-lbs if you can't measure stretch. My concern was that at 75 ft-lbs, I only had .004" of stretch on the first bolt. Going up to 85 ft-lb made no difference, and I was afraid to go much tighter. I tightened all 16 bolts to 85 and only 3 reached .500". I called ARP and they didn't offer much except to say that stretch is the preferred method, and that I should call the rod manufacturer, so that's what I did. I called Callies and talked to their tech. He agreed that torquing the hell out of the bolts to get the .005" stretch didn't seem like a good idea, and ultimately suggested that I stick with my 85 ft-lb tightening.
So, at least I have some progress! There is a guy interested in my corvette too, so with any luck, I'll have the cash to move forward with the project again soon.
Here are a few pics of my bottom end:
Old Aug 8, 2011 | 09:28 PM
  #121
mw66nova's Avatar
Engine: 7.0L
woot! that's great news jim! i was hoping to see some progress on this soon!
Old Aug 8, 2011 | 09:50 PM
  #122
Jim85IROC's Avatar
Progress has been long overdue. Now, back to my bathroom remodel.
Old Aug 8, 2011 | 09:53 PM
  #123
mw66nova's Avatar
Engine: 7.0L
so whatever happened to iroczone?
Old Aug 9, 2011 | 08:50 AM
  #124
Jim85IROC's Avatar
The guy that's hosting it has it on some POS computer that goes down more than a $20 transvestite. It's been down so much lately that I think most if not all of the forum members have moved on. I'm contemplating moving it to a more reliable site (that I'd have to pay for), but frankly, that site really didn't have much to offer that TGO doesn't have too.
Old Aug 9, 2011 | 10:56 PM
  #125
jamieschott's Avatar
Awesome thread! Great reading also.
Old Aug 11, 2011 | 11:39 PM
  #126
sk8r fer life's Avatar
Car: 1990 camaro rs
Engine: 305 tbi
Love all the attention to detail. Good job on doing it the right way.
Old Aug 14, 2011 | 07:03 PM
  #127
Jim85IROC's Avatar
Well, the Corvette sold today. It hurt to watch the guy drive off with it. But, at least it means that now I have the money to move forward with the project. I guess that I should decide which trans to go with. I'm considering a rebuilt t56 or a Magnum t56.
Old Aug 25, 2011 | 10:00 PM
  #128
Jim85IROC's Avatar
A coworker offered to let me borrow his spring compressor, and since I still hadn't perfected my DIY version, I took him up on his offer. Unlike the one my father has, this one was rigid enough to actually do its job with these springs, so I was able to re assemble the heads with my PRC springs.
Here's a pic of the spring compressor holding one of the springs down:
The first head went quickly, but on the 2nd head, the first intake valve I got to was a bastard. With the tool adjusted the same as on the other head, I couldn't compress the spring quite enough, and if I went to the next notch on the tool, it compressed it too much. I had to shim the tool to do the intake valves:
Here's one of the heads all done:
Old Sep 16, 2011 | 06:45 PM
  #129
Jim85IROC's Avatar
Here's a bit of an update. Over the last few weeks I've ordered up almost all of the stuff I need to finish the motor. One of the only things that I'm lacking now is the cam. Choosing a cam for an LS3-headed motor is way more complicated than it should be. There are 2 camps out there, the camp that likes split duration cams with a bunch of exhaust duration, and those that like more intake and less exhaust. Decisions decisions...
But, in the meantime, at least I made some progress. Part of my bag of new parts included 8 new intake rockers and the Comp trunion kit.
Sorry for the poor picture quality. I forgot my camera so I had to use my phone.
First I started by pressing out the factory trunions:
Next, you press the new bearing into one side:
All pressed in:
Then you turn the rocker over, put the trunion in, stand it on a washer, and press the 2nd bearing into place, with another washer to provide clearance for the trunion:
Trunion & bearings installed:
Install the snap rings, rinse and repeat 15 more times.
Old Sep 16, 2011 | 09:43 PM
  #130
mw66nova's Avatar
Engine: 7.0L
that is an excellent quick cheap upgrade to help keep peace of mind with the rockers. it's such an easy upgrade, i did mine in a bench vise with some sockets. lookin good jim! keep us posted!
Old Sep 16, 2011 | 09:53 PM
  #131
Jim85IROC's Avatar
Way too many pics of trunion bearings in oil pans on 'tech. With the lift I'll be running, I sure didn't want to gamble.
Old Sep 19, 2011 | 07:54 PM
  #132
Spike-Z's Avatar
Car: IROC-Z
Engine: LSx
Axle/Gears: Fabbed 9"
Looking good Jimbo!
I second the trunion upgrade kit. Cant beat the peace of mind/price ratio.
Old Sep 22, 2011 | 02:58 PM
  #133
6SIX6's Avatar
Car: 89 IROC
Engine: LSX 6.0 370, TU2 Cam, Fast intake
Transmission: T56 w/ lots of goodies
Axle/Gears: 8.8, Posi, 4.10, 31 Spline
Awsome build thread and Ive learned alot more now. After reading this I will be doing the trunion mod as well to my stock rockers. Keep up the awsome work and look forward to more updates
Old Sep 22, 2011 | 03:59 PM
  #134
Jim85IROC's Avatar
Well... I FINALLY ordered my cam.
I talked to Don at Slowhawk, which is who will be doing my dyno tuning. He's the one that's going to determine my timing and fueling events, it makes sense to let him decide my valve events too.
Wound up with a 228/232 on a 115 lsa. Lift is a little lower than I'd figured (around .610) because he prefers a little bit less aggressive cam lobe in order to help keep the valves and seats alive. Peak horsepower might not get to the magical 500 RW number that I'd hoped, but I'm willing to trade good fat torque and excellent driveability for a few peak hp.
Once it gets here I can finally finish the motor.
Old Sep 22, 2011 | 05:29 PM
  #135
mw66nova's Avatar
Engine: 7.0L
wow that's a small cam....smaller than what's in my cathedral port 370
Old Sep 22, 2011 | 07:06 PM
  #136
Jim85IROC's Avatar
Ls3 heads don't respond to bigger cams. The intake valve is massive, so it needs way less cam than cathedral heads. Any more duration and you start getting too much overlap, which kills power because of reversion issues. This combo should get me at or near 500rwhp with stock drivability.
Old Oct 4, 2011 | 06:41 PM
  #137
Jim85IROC's Avatar
Cam is here. Specs are slightly different than what I was expecting. 227/231 613/617 114+3 The lobes are Comp LSL lobes
I suppose now would be a good time to order a degree wheel.
EDIT: Degree wheel ordered.
Old Oct 4, 2011 | 09:13 PM
  #138
cam-'s Avatar
Car: Camaro
Engine: 6.2L
LSL lobes ftw with LS3 heads
Very similar cam to what Im running actually and I spent considerable time choosing as well. Mind you Im only hoping for 450 whp and considering anything above that a bonus but Im also only at 378 cubes so giving up a good bit there.
Old Oct 4, 2011 | 09:27 PM
  #139
Jim85IROC's Avatar
The guy doing my tune (who also helped me choose a cam) said similar combos to mine have made 525hp/500tq on his Mustang dyno. We'll see. That sounds optimistic to me, especially the torque. My goal is 500rwhp with stock-like driveability.
Old Oct 4, 2011 | 09:29 PM
  #140
cam-'s Avatar
Car: Camaro
Engine: 6.2L
Sounds promising indeed
Old Oct 10, 2011 | 10:02 PM
  #141
Jim85IROC's Avatar
Started my cam installation tonight.
Here's a pic of the cam:
A word of advice. Clean the inside of the cam! I looked inside and it was nasty. This was the crap that came out of it:
Prior to the installation, I also installed the seals into the front and rear covers.
Here's the rear cover without the seal. Notice that the stock seal also comes with an aligning tool:
To install the seal, GM sells some specialty tools. I happened to have some of my own:
They worked great!
Front cover without the seal:
Front cover with the seal:
Here's a picture of the cam almost home:
continued next thread...
Old Oct 10, 2011 | 10:03 PM
  #142
Jim85IROC's Avatar
Continued from last thread...
For those doing a build, the original style cam retainer plate was discontinued. The replacement part does NOT use the same bolts, so make sure you buy those too! Here's a pic of the two plates side to side. The new one is the one on the right with the flush-mount torx bolts. These new bolts only tighten to 11ft/lbs instead of the 18 that the old style torque to:
Cam plate installed:
Now everybody gets to hear about my boneheaded move. I pushed the crank gear onto the shaft, tapped it on, then drove it home with the harmonic balancer bolt, using the old gear acting as a spacer. I couldn't get it quite flush to the crank. I got a bigger ratchet. Twist, twist, POW! Things got all loose. I pulled it back apart, and discovered this:
It turns out, I'm a dummy. I installed the gear backwards, with the teeth facing AWAY from the block instead of toward it. The chamfer on the crank resulted in a split gear once I applied a bunch of torque. Dumb, dumb, dumb.
So, the cam installation sits until I can order a new gear from the dealer. :-/
Old Oct 10, 2011 | 10:15 PM
  #143
Mkos1980's Avatar
Car: Formula
Engine: 6.0 LSX
Axle/Gears: 9 Bolt 3:27
In looking for cams, GMHTP did a nice cam only upgrade on an LS3 and was rewarded with 46X RWHP. I think it was a 228/242 629/620 112. In the book it was stating that the LS3 heads need alot more exhaust duration due to the port differances. Now I'm all confused as I was thinking of maybe doing another H/C package in the future. I'm running a 228/230 585/585 112 cam now and it seems like a baby on my motor.
Old Oct 10, 2011 | 11:22 PM
  #144
88blackiroc's Avatar
Car: 88 Iroc-z
Engine: ls1
Transmission: t56
Let me be the next to say subscribed! Good thread and love the pics. Makes me wish I stored money to build my block
Old Oct 11, 2011 | 02:44 PM
  #145
Jim85IROC's Avatar
Some people seem to give these a ton of exhaust duration, but the problem with that, is that in order to maintain minimal overlap, you have to cut your intake duration way back. The "other" camp feels that your power production comes from the intake duration, so the lesser of all evils is to sacrifice some exhaust duration. Based on numbers I've seen, it mostly all winds up being a wash. The only way to really kill your power with these heads is to have a ton of overlap. I went back and forth for months trying to come up with the "right" cam spec, but I've just come to the conclusion that if there was just one right way to do it, that's how everybody would be doing it! Ultimately I decided to trust the advice of the guy doing my tune. He's going to have total control over my fuel and spark events, I decided to just give him control of my valve events too. Fortunately, other than being 3-4 degrees milder on the duration compared to what I was originally set on, he was right in line with what I had wanted.
Just got off the phone with the dealership to order the new crank sprocket. Order had to be in by 3:30. I called immediately after the order was finalized. :-/ Fortunately, it'll still be here on Thursday.
Old Oct 15, 2011 | 05:46 PM
  #146
Jim85IROC's Avatar
Sort of an update. I took the car to Dyno Day at Slowhawk Performance in Bridgewater MA today. He'll be doing my tune after I put the new motor in, so I thought it would be great to get a "before" number with the current motor. As a refresher, the current motor is a .030 over 350 with forged flat top slugs, stock crank & rods, 461 fuelie heads (terrible heads for TPI), accel base, SLP runners, 24lb injectors, headers, 3" exhaust, and a 214/224 flat tappet cam. Car has a T5 and a 10 bolt.
The car put down 251hp on the first run, and 249 on the 2nd run, along with 331ftlbs of torque. These were rear-wheel numbers on a Mustang dyno. The car did better than I expected.
Here's a video of the run:
http://www.youtube.com/watch?v=Nzsw5BeVxLs
Old Oct 18, 2011 | 09:17 PM
  #147
Jim85IROC's Avatar
Tonight I did a little bit of work, along with some educational disassembly.
First, the work. I installed the new crank gear, then the cam gear & chain. I discovered that the bolts that came with the timing gear set were too long and bottomed out in the Comp cam, so I reused the stock bolts, and tightened to 24ftlbs.
The next step is to install the oil pump. Based on a lot of advice on 'tech, I bought an "LS6" pump. I also have my stock LQ9 pump, and another used pump of unknown origin that I believe was also said to have been an LS6 pump.
Here are the three of them. My LQ9 pump is on the bottom, the unknown pump in the middle, and my new LS6 pump on the top:
The back. The two old pumps are made in Canada, the new one in Mexico:
I decided to take apart the old one:
Gears out:
Here's the crank gear installed to show how the pump works. As the crank gear turns, it squeezes the two gears together, which pushes the oil into the area under the gears, out the hole and into the block:
Continued next post (when the hell did TGO go down to an 8 image limit???)
  #148
Jim85IROC's Avatar
continued..
Here's all 3 taken apart:
Here's the outlet on the new LS6 pump:
And here's the outlet on the old, unknown pump:
Of the 3, the new LS6 pump housing looks the worst. The machine work on the outlet hole is crap, and the casting is rough. Right now I'm a bit undecided on what to do. I don't know if I want to just run the new pump as is, port the new pump, or run the unknown or original pump as is. Honestly, both of the old pumps look perfect inside, and both are better made than the new LS6 pump.
Old Oct 18, 2011 | 11:14 PM
  #149
Pocket's Avatar
Car: 91 Trans Am
If you reuse an old pump, be sure to pop the bypass valve out and clean the cyl extensively so movement is fluid. With gerator pumps, failure usually isnt by the pump, but instead a stock valve bypassing too much oil so the system cannot maintain adequate pressure. This starves bearings and ruins your day
You can try porting the pump, which essentially is knocking the sharp edges off the inlet and shaping the round outlet hole into a smoothed funnel shape. Shimming the bypass valve spring with a small washer or nut wont hurt to build a few more pounds of pressure
Old Oct 19, 2011 | 07:12 AM
  #150
Jim85IROC's Avatar
Is there a benefit to having more pressure? Generally you're only going to reach that higher pressure at higher RPM when you've already got substantially more oil going through the system anyway.
