LT question.
Old Aug 12, 2010 | 03:24 PM
CrazyImages's Avatar
Car: 1988 Camaro Rs
Engine: LH0 V6
LT question.
n.a
Old Aug 12, 2010 | 03:57 PM
chevyowner02's Avatar
Car: 1992 camaro
Axle/Gears: 3:73
Re: LT question.
It really depends on the "rebuild" that could be a simple ring,bearing,gasket kit to needing bored,crank turned......
IIRC when I rebuilt mine I had around $1200 in it but that was a cam, ARP bolts, new water pump........
As for the transmission I would go with the 4L60E or the T-56.
Old Aug 12, 2010 | 09:02 PM
Pocket's Avatar
Car: 91 Trans Am
Re: LT question.
Id find a lower mileage dropout instead of a stock rebuild. If you're planning on a nasty engine with a mostly aftermarket setup, then by all means build it to the gills with a cheap bare block
Old Aug 12, 2010 | 10:50 PM
Car: 1988 Camaro Rs
Engine: LH0 V6
Re: LT question.
n.a
Old Aug 13, 2010 | 07:16 AM
Klortho's Avatar
Car: 1987 GTA
Axle/Gears: 9 bolt 3.70 posi
Re: LT question.
I have around 600 bucks for the rebuild on mine, that's new bearing, rings, oil pump, gaskets and having new valve guides installed as well.
Machine work was honing the cylinders, 3 angle valve job and valve guides, hot tank the block, magniflux the rods, turn the crank new cam bearings installed and new freeze plugs.
ZZ3Astro
Aug 13, 2019 12:57 AM
fbodyfreakls1
Oct 6, 2015 06:34 PM
corey8084
Sep 17, 2015 02:56 PM
Wylecoyote08
Sep 8, 2015 08:26 AM
Ian Irvine
Sep 4, 2015 08:08 AM
