coolant crossover tube question
Car: 1989 camaro
so im nearing completion on my LSX swap and trying to figure out what i am supposed to do with this.. its the one on the front of the heads... what am i supposed to do with this?
thanks for any help
thanks for any help
Car: 86 TA, 91 B4C
Engine: 5.3, 4.8
Transmission: 4L80 4000, T56
Axle/Gears: 4.30 M12, 23.42 10 bolt
Re: coolant crossover tube question
Me and most others i see run it into a T on the heater core line, works fine for me, there are pics posted somewhere of the same T i used.
Car: 89 IROC-Z
Engine: 370 LSX, LS3 Top End
Transmission: Built T-56
Axle/Gears: 9" Aluminum Center 3.89's
you can also tap it into the top of the water pump
Engine: Cammed 6.0L LSX
I ran a hose from the crossover tube to the top outlet on the passenger side of the radiator.
Car: 89 IROC-Z
Transmission: 4L80E/4L80E
The best place to route it is to the radiator tank just below the cap. Most 3rd gen radiators have some sort of nipple there.
Car: 1987 Trans Am
Engine: LQ9/L92
i bought a low mile water pump and the previous owner had tapped the top for a temp guage; guess which route i'm going
1992 Trans Am
May 10, 2023 07:19 PM
