Anyone ever have a lifter dry out?
Old Aug 22, 2010 | 05:48 PM
9014josh's Avatar
Car: 1988 TA
Engine: TPI 350
Transmission: auto
Axle/Gears: 3.27's
Still trying to figure out the noise in my 95 lt1 motor it sound to be in the top end of the motor tonight,i took off the timing cover tonight and only found that the chain was stretchted but not bad enough to make a nock at 2k RPM.
My guess as well as a few other people that have looked at it say that i have a bad lifter,anyone else had this happen?
Old Aug 23, 2010 | 11:03 AM
Pocket's Avatar
Car: 91 Trans Am
Re: Anyone ever have a lifter dry out?
A failed lifter isnt unheard of. Lucky for you LTx lifters only require pulling the intake and a valve cover
Old Aug 23, 2010 | 01:00 PM
89ROC-Z's Avatar
Car: 89 IROC-Z
Engine: 370 LSX, LS3 Top End
Transmission: Built T-56
Axle/Gears: 9" Aluminum Center 3.89's
Lifters usually start nocking or ticking when they don't pump up anymore. They're cheap too.
Oh and i found out the other day at tpis that the RHS block allows you to pull lifters without pulling the heads!
Old Aug 25, 2010 | 07:26 PM
9014josh's Avatar
Car: 1988 TA
Engine: TPI 350
Transmission: auto
Axle/Gears: 3.27's
i knew i didnt have to pull the heads,im hoping thats all i have is a dry lifter..i also noticed that my timing chain is pretty sloppy,like a 1/4 inch of slop in it..
tyeo098
Nov 30, 2015 06:27 PM
codeysabatini
Nov 10, 2015 04:07 PM
skinny z
Oct 5, 2015 06:23 PM
TX-SleeperC5
Sep 24, 2015 03:13 PM
dimented24x7
Sep 6, 2015 03:51 PM
