Computer Mounting
Old Aug 23, 2010 | 04:49 AM
BlueMagicSS's Avatar
Car: 2000 Camaro SS/86 Iroc/89 Iroc(x2)
Transmission: 6 Speed
Axle/Gears: 4.10
Computer Mounting
So I see a lot of people mounting their PCMs behind the dash in the stock location. I wanted to know what you all used to mount it and if you have any pics of it. Thanks
Old Aug 23, 2010 | 07:53 AM
ghettocruiser's Avatar
Car: 86 Trans AM
Engine: LS1 (not stock...)
Transmission: Built T56
Axle/Gears: Strange 12-bolt w/ 3.73
Re: Computer Mounting
Mine fit up in the original spot pretty tightly. I tried to figure out a way to use the original LS1 pcm cradle, but in the end, i just made a metal bracket to support the pcm. It doesnt really hold it securely, but the PCM cant go up, or down, or side to side. So I figured it was good.
Its basically just a piece of fairly heavy aluminum. I bent it to give it some strength, and used the original ECM mounting screws to hold it in place. Working great for the last couple years.
This was during the testing phase.
And this is all you see from the passenger compartment.
J.
Old Aug 23, 2010 | 09:44 AM
Ramair21's Avatar
Car: Camaro RS/SS
Engine: 5.7 LS1
Transmission: 4L60E Transgo shift kit, 3500 stall
Axle/Gears: 4th Gen Rear 3:42
same here. I just pushed that sucker in and it didnt move a bit. Its been 5 years with no issues.
Old Aug 23, 2010 | 10:55 AM
Pocket's Avatar
Car: 91 Trans Am
Its a tight fit in the stock location as-is. I wrapped it in an old towel to kill vibrations and used a piece of cable to hold it up since theres nothing to attach a bracket to. With the hush panel on, mine looks like ghettocruiser's
Old Aug 24, 2010 | 03:14 AM
Axle/Gears: 4.10
Sounds good!!!
@Pocket.... I know I'm going to need a harness from you... but I don't have the harness from that car anymore.... will you need that to build a harness for me?? and PM me with a price on the harness. Thanks
Matt
89-91fun
South West Region
Sep 12, 2015 03:06 PM
Stryker412
Sep 7, 2015 09:11 AM
FormulasOnly
Sep 6, 2015 10:42 AM
SG91camaro
Sep 5, 2015 10:27 PM
IROCZDAVE (88-L98)
Sep 2, 2015 08:49 AM
