LT1 swap w/ T5..Which gears to install
Car: '98 Mustang GT
Engine: '03 4.6L
Transmission: T45
Axle/Gears: DK
The LT1 motor and T5 trans are in my '89 and I've started the wiring harness. The PCM was sent out today. Slight issue is that they need to know, which gears I will be running. Currently, I have the 2.73's. I'm going to swap in either 3.42's or 3.73's. Any opinions on which gears to go with? Also, the T5 is staying in for now (until it breaks or I find something stronger). Any advice is appreciated. Sorry if this is posted in the wrong section.
Car: 1991 RS
Axle/Gears: 4.11
Re: LT1 swap w/ T5..Which gears to install
I'd recommend 3.42 gears since you are short a gear. The T-5 isn't going to hold up against an LT engine unless you are light on the throttle.
On Probation
Engine: several
Transmission: none
Axle/Gears: none
If the T5 was behind a TBI, then it has the 0.63:1 fifth. If it was behind a TPI, it has the 0.73:1 fifth.
With the 0.63, I'd run a 4.10:1 gear. That'd be best for low elapsed times, plus deeper axle ratios effectively reduce the stress on the transmission, whether stick or automatic.
LT1s still get good mpg even with way too much cruise rpm. I did 22 mpg running 80 mph at 2600 rpm, in my '95 Z28 convertible.
Car: '98 Mustang GT
Engine: '03 4.6L
Transmission: T45
Axle/Gears: DK
Car: 1991 Camaro Z28
Engine: 357, Canfield heads, solid roller,
Transmission: Upgraded 03 Cobra T56
Axle/Gears: 9" 3.50 gears and Detroit Locker
If you have the trans out of the car now, put it in 5th and accurately mark the top of the input shaft and the output shaft. Now turn the input exactly 1 full turn and see where the output is. Is it closer to being 180 degrees from where it started or is closer to 270 (3/4 of a turn) from where it started. If it is the .63 ratio, I would agree on the 4.10's. My T56 has a .63 ratio 6th gear and with the 28" tire I plan on running, my 75 mph cruise rpm will be 26xx with the 4.56 gear I'm going to swap to. A big OD gear is nice for this.
If you have the other ratio 5th gear, then the decision may come down to how much highway driving you do and what are you expectiations of the car. On a stock size tire, even 3.73's with the .73 overdrive will have higher rpms in 5th gear than 4.10's with a .63 overdrive at the same speed.
Here is a link to a calculator you can play with. Just put in the size tire your running, the axle ratio and your trans gear ratio.
http://www.fbody.com/calc.htm
Car: '98 Mustang GT
Engine: '03 4.6L
Transmission: T45
Axle/Gears: DK
Not entirely true. My T-5 lasted 2 years behind a Hotcammed LT1. Synchros didn't last more than a year, but everything else was fine. I hammered the crap out of it though.
Car: 1991 RS
Axle/Gears: 4.11
Car: '98 Mustang GT
Engine: '03 4.6L
Transmission: T45
Axle/Gears: DK
I will probably do some hammering on it. As long as it lasts until I find something stronger (i.e. T56 or TKO 500/600).
Car: 1991 RS
Axle/Gears: 4.11
hehe, good luck =) With hammering your synchros will be lucky to last a month. Be easy on it, and you might get a year or so out of it. The T-5's from third gens just weren't designed to put up with much of a beating.
Car: 91 Z28 convertible
Engine: 96 LT1 5.7
Transmission: t5 5speed
Axle/Gears: 3.73 gears
whats up guys. i havent been on for a while. hey TexasLT1 you pasky helped me out with my lt1 install and i have a t5 on my lt1 since 2004 and its still working good. when i drive it i get on it no problem. although i do have fan relay issues and charging issues its all good
Car: 1991 RS
Axle/Gears: 4.11
Hehe, goes to show there is always variation in all things. I hope your T-5 Experience is just like his, lasting 6 years is great!
RedLeader289
May 28, 2019 01:47 PM
3rd, 700r4, gen, generation, install, lt1, motor, overdrive, pics, studebaker, swap, t5, thirdgen, trans, transmission
Stock LT1, T5 will hold up fine.
