ls3 swap cai
Old Sep 2, 2010 | 06:47 PM
JSACRA's Avatar
Car: 89 IROC-Z
Engine: 6.2 LS3
Transmission: MN12 T56 GTO
ls3 swap cai
need ideas and pics of cold air intakes for a ls engine swap
Old Sep 2, 2010 | 07:36 PM
kizmaro89's Avatar
Car: 89 Camaro RS
Engine: LM7
Re: ls3 swap cai
2004 GTO K&N CAI works and looks great. There are a some pics of guys with that setup around this board
Old Sep 2, 2010 | 09:42 PM
Pocket's Avatar
Car: 91 Trans Am
Re: ls3 swap cai
Most build their own with tubing and rubber/silicone connectors. Personal preference really. Cost is very similar any route you take
Old Sep 6, 2010 | 07:55 PM
JSACRA's Avatar
Car: 89 IROC-Z
Engine: 6.2 LS3
Re: ls3 swap cai
how about some pics and what parts u guys used
Old Sep 6, 2010 | 09:07 PM
Shift06's Avatar
Car: 1991 Trans Am GTA
Engine: LSX (swapping)
Transmission: 4L60E (swapping)
Axle/Gears: 2.73 Posi 10 Bolt
Re: ls3 swap cai
I used:
(1) 4" to 4" 90* rubber elbow
(1) 4" to 4" 45* rubber elbow
Section of 4" aluminum tubing
(5) 4" clamps
(1) K&N filter, I don't have the part number, it's a 4" inlet though, 7 or 9 inches long.
Bought all the parts from www.intakehoses.com
Old Sep 6, 2010 | 09:35 PM
JSACRA's Avatar
Car: 89 IROC-Z
Engine: 6.2 LS3
Re: ls3 swap cai
anyone tried the 05 gto k&n cai it looks to be a lil straighter not so many bends
Old Sep 6, 2010 | 10:18 PM
Pocket's Avatar
Car: 91 Trans Am
Re: ls3 swap cai
Cheap spectre 4" filter
2x 4" strait connectors with T-bolts
4" 90* mild steel exhaust tubing
4" 45* mild steel exhaust tubing cut in half mid bend and welded to the 90*
Tight fit, looks great, works great, good MAF readings, reasonable IATs, inexpensive compared to a prebuilt piece
Old Sep 6, 2010 | 11:28 PM
timmyboy's Avatar
Car: 91 z
Axle/Gears: moser 9"
Re: ls3 swap cai
I made mine out of aluminum 4" piping. I dont have any completed pics but it look great!! And its the best cold air intake you can have!
Old Sep 22, 2010 | 01:57 PM
JSACRA's Avatar
Car: 89 IROC-Z
Engine: 6.2 LS3
Re: ls3 swap cai
looks pretty good any one else want to chime in?
Old Sep 22, 2010 | 02:24 PM
1ADan's Avatar
Car: 1987 Trans Am
Engine: LQ9/L92
Re: ls3 swap cai
I was looking at some of the cheap 4th gen / gto kits on ebay. you can usually find em for under $100. dont mind doing a little bit of cutting if needbe for that price.
Old Sep 22, 2010 | 03:41 PM
Pocket's Avatar
Car: 91 Trans Am
Re: ls3 swap cai
If you can find one for that price, buy it. DIY things like mine are nearly that in materials
The two 4" bends are nearly $50, plus the $30 filter. Couplers $8 ea and clamps about $4 ea
Then I had to weld it together
Old Sep 23, 2010 | 01:05 AM
Z28FAST1's Avatar
Re: ls3 swap cai
i thought about making my own but loved the looked of the New Era CAI's. About $250 for the LS2 version with the 90mm TB.
Old Sep 23, 2010 | 02:41 AM
sargenewk17's Avatar
Car: 92 Camaro RS
Engine: LS2
Axle/Gears: 12-Bolt with 3.73
Re: ls3 swap cai
I used an '06 GTO K&N kit for mine. I cut it just after the elbow that goes into the TB and turned it 180* to move the conical air filter down behind the driver side headlights. I made an airbox out of thin stainless steel to seal the cavity up to the hood. I can't get pics cause I'm overseas. I would be willing to bet that making your own out of separate components is significantly cheaper than buying a kit and modifying it though.
Old Sep 24, 2010 | 06:23 PM
JSACRA's Avatar
Car: 89 IROC-Z
Engine: 6.2 LS3
Re: ls3 swap cai
pic would be great, are the 06gto as same as the 05 gto?
Old Feb 19, 2011 | 04:19 PM
JSACRA's Avatar
Car: 89 IROC-Z
Engine: 6.2 LS3
Re: ls3 swap cai
any other suggestions im still deciding.
Old Feb 19, 2011 | 06:29 PM
1ADan's Avatar
Car: 1987 Trans Am
Engine: LQ9/L92
Re: ls3 swap cai
I'm playing guinea pig here, just ordered one of these:
http://cgi.ebay.com/ebaymotors/ws/eB...K%3AMEWNX%3AIT
wont be on the car any time soon though - still has about a foot of snow on it....
Old Feb 19, 2011 | 07:39 PM
1nasty86's Avatar
Car: 1986 camaro
Engine: ls2
Transmission: FLT stage 6 60e
Axle/Gears: 8.8 with 3.73's
Re: ls3 swap cai
New 4' cai. Made out of a u bend and a 12 inch peice of silicone.
Old Feb 19, 2011 | 07:59 PM
BlueZee28's Avatar
Engine: Cammed 6.0L LSX
Re: ls3 swap cai
I'll post up the one I made for my car and the one on my dads car. They're a little different from each other as mine goes down through the sheet metal tray and in front of the wheel, his is completely in the engine bay. I'll post them later I'm out with wifey right now.
Old Feb 19, 2011 | 11:57 PM
White'89's Avatar
Car: '89 GTA
Engine: 5.7L LS1
Axle/Gears: 9 bolt 3.27
Re: ls3 swap cai
Is that thing at all awkwardly heavy pocket? I already have the same materials you used to make that at my disposal but I was afraid it would be a tad bit on the heavy side compared to one made out of the thin aluminum tubing for a relatively equal price.
Old Feb 20, 2011 | 12:34 AM
BlueZee28's Avatar
Re: ls3 swap cai
Mine:
My dad's:
Old Feb 20, 2011 | 10:01 AM
Omega's Avatar
Car: 89 Formula / 09 G8
Engine: LS1 / LS3
Transmission: M6 / M6
Axle/Gears: 3:42 / 3:27
Re: ls3 swap cai
Not the best pic, but you get the idea. 4" aluminum. Sounds like the worlds most powerful vacuum at idle, anyone else have the same sound?
Old Feb 20, 2011 | 12:17 PM
1nasty86's Avatar
Car: 1986 camaro
Engine: ls2
Re: ls3 swap cai
kerby here also!
Old Feb 20, 2011 | 12:38 PM
robbe_iroc's Avatar
Car: 1989 Iroc
Engine: LS2
Transmission: GTO T-56
Axle/Gears: 4:th gen Auburn with 3:73
Re: ls3 swap cai
Here some pics of my 4" aluminum tubing on my LS2 swap Iroc.
90 degree silicone bend and 45 degree alu tube. Huge K/N filter that gets some cold air from a hole in the drivers side battey tray.
Attached Thumbnails ls3 swap cai-ytterliggare-en-sn-skotur
Pocket's Avatar
Car: 91 Trans Am
Re: ls3 swap cai
About 5lbs with the filter. I chose steel over aluminum because I cant weld alum
Old Feb 20, 2011 | 12:41 PM
robbe_iroc's Avatar
Car: 1989 Iroc
Engine: LS2
Re: ls3 swap cai
SiCkRs
Members Camaros
32
Jul 1, 2018 04:53 AM
Trickskier
Aug 29, 2015 01:12 PM
theshackle
Aug 22, 2015 06:52 PM
Hello, Michael
Aug 20, 2015 03:19 PM
