PS -AN Lines.
Old Sep 3, 2010 | 05:33 PM
Mkos1980's Avatar
Car: Formula
Engine: 6.0 LSX
Axle/Gears: 9 Bolt 3:27
PS -AN Lines.
Does anybody know what size adapter I need to put the an lines to on the gear box and on the pump? I know is 6 AN to an o-ring But I dont know what size the Oring side is...
Old Sep 3, 2010 | 07:30 PM
88 350 tpi formula's Avatar
Car: 89 FORMULA 350, 91 Z28 Convertible
Engine: ls1, LB9
Transmission: t56, Auto
Axle/Gears: S60/ 3.73
Re: PS -AN Lines.
if its what I think your asking you would use the sag fitting (used on the old FI feed line ) might be worth grabbing one and test fitting it befor you order
Old Sep 3, 2010 | 10:05 PM
FSTFBDY's Avatar
Car: 92 Z28
Engine: Boosted LSX
Re: PS -AN Lines.
If I recall..
(1) 16mm O-ring to -6AN adapter for the pump
(1) 18mm O-ring to -6AN adapter for the steering box
I swapped mine over to AN and good lines.
I have a local contact back in ohio who makes custom lines for PS and brakes if you want his info. or sells just the parts. I got all my AN fitting and lines for the supercharger plumbing, etc.. for less then summit , etc..
(he makes over 250,000 custom lines a year) for brembo , willwood, summit, etc.
pjsparts
Oct 29, 2025 06:39 PM
AmpleUnicorn88
Brakes
32
Nov 18, 2015 11:02 AM
87v6Bird
Brakes
Oct 4, 2015 07:37 AM
roysatikas
Sep 22, 2015 08:15 PM
sreZ28
Carburetors
24
Sep 21, 2015 04:54 PM
