lm7 block deal
Old Sep 4, 2010 | 06:05 PM
SiCkRs's Avatar
Car: 91Z28
Engine: 5.7 ls1
Transmission: 4l60e
lm7 block deal
Hey i wanted to get all of your guys opinion if i should buy a lm7 long block but is missing one of the valves on one of the heads. It has no accessories its just the long block the guy is willing to let it go for $150 does that sound like a good deal or would it be best to find a parts car for the swap.
Old Sep 4, 2010 | 06:51 PM
Pocket's Avatar
Car: 91 Trans Am
Re: lm7 block deal
Heads are worth that much
Buy it, but dont expect it to last 100k as-is
Old Sep 4, 2010 | 07:11 PM
SiCkRs's Avatar
Car: 91Z28
Engine: 5.7 ls1
Transmission: 4l60e
Re: lm7 block deal
ok so its a good deal, and yes i am aware that it wont last 100k unless i rebuild it
Old Sep 4, 2010 | 07:41 PM
1ADan's Avatar
Car: 1987 Trans Am
Engine: LQ9/L92
Re: lm7 block deal
what else is included? the little stuff adds up real quickly. i bought an ls1 longblock for $300, but it had nothing but heads and rotating assembly. i ended up buying a 5.3 for another $300 just to get the sensors, covers, etc.
that is a great deal, just be ready to get the budget together for everything else too
Old Sep 4, 2010 | 11:15 PM
SiCkRs's Avatar
Car: 91Z28
Engine: 5.7 ls1
Transmission: 4l60e
Re: lm7 block deal
Just the long block but he said its missing a valve in one of the heads, no accessories or sensors
Old Sep 5, 2010 | 02:46 PM
BlueZee28's Avatar
Engine: Cammed 6.0L LSX
Re: lm7 block deal
I would hold off. That is a good deal to someone that already has a swapped car and the motor grenaded an they just need another block to use. But you can get a complete motor with accessories and sensors and all the injectors and all that stuff for $500 being a 5.3, and if you try and source out the rest of the parts missing I know you're gonna spend more than $500.
Old Sep 5, 2010 | 04:13 PM
dust3r's Avatar
Car: 1986 z28 & 1992 z28
Transmission: 700-R4
Re: lm7 block deal
Are you doing a CA smog legal swap? I don't think you can put a truck motor into a car.
Old Sep 5, 2010 | 04:26 PM
83C_CamAroZ28's Avatar
Car: 1983 Z-28
Engine: 5.7 L
Re: lm7 block deal
u can put any motor in any car or truck in CA....u just have 2 notice CHP that u have swaped out the engine and that it will pass smog...i had/have a truck engine in my camaro I'm rebuilding it rite now...and it did pass smog...
Old Sep 7, 2010 | 03:26 PM
SiCkRs's Avatar
Car: 91Z28
Engine: 5.7 ls1
Transmission: 4l60e
Re: lm7 block deal
Ok thanks thats what i really wanted to know if i would spend more to get the accessories and other things then what the engine would cost and as for smog this is mainly gonna be a track car once i do my lsx swap
Old Sep 9, 2010 | 04:51 PM
Guest
Guest
Posts: n/a
Re: lm7 block deal
LM7 can be bored to 5.7L, and pieced together cheaper than paying for a real LS1. I'd buy it. I don't know as I'd install it, or even rebuild it just yet, however.
Old Sep 9, 2010 | 09:20 PM
Pocket's Avatar
Car: 91 Trans Am
Re: lm7 block deal
Buy it, sell the heads for $200, use the rest to piece together a partial engine or keep as spares
Old Sep 10, 2010 | 08:11 AM
Jim85IROC's Avatar
Car: 85 IROC-Z / 88 GTA
Axle/Gears: 3.42 / ?
Re: lm7 block deal
I'd want to look the motor over before plunking down the cash... why is it missing 1 valve? I'd need that question answered to my satisfaction before I bought it. If it dropped that valve while the motor was running, don't waste your money.
Old Sep 10, 2010 | 08:28 AM
Atilla the Fun's Avatar
On Probation
Engine: several
Transmission: none
Axle/Gears: none
Re: lm7 block deal
That's a good point, but how the heck is an LM7 gonna drop a valve? I'd say either manufacturing defect, or it got pulled for some other reason. We all saw that article in Car Craft where they fitted a well-used LM7 with the prototype Thumpr cam and a single plane, then twisted it to 6900 rpm with stock valves.
Old Sep 12, 2010 | 04:14 AM
SiCkRs's Avatar
Car: 91Z28
Engine: 5.7 ls1
Transmission: 4l60e
Re: lm7 block deal
The guy said that he does not know the ast of motor so which is the reason he's selling it cheap so I I'm thinking it might just be a scam
Old Sep 14, 2010 | 11:21 PM
SiCkRs's Avatar
Car: 91Z28
Engine: 5.7 ls1
Transmission: 4l60e
Re: lm7 block deal
Guess what you guys today i seen on craigslist for a ls1 with a auto tranny and all accessories and i offered him $1k and said he will take it would that be good for a swap and another $500 to do the swap for i could take out a loan or is it a ok deal and come around often. Im just not sure around how muh these engines are worth thats why i am asking for some help.
http://losangeles.craigslist.org/wst...941299718.html
Old Sep 14, 2010 | 11:37 PM
dynodanmanda79's Avatar
Car: 1989 IROC-Z, 1979 Malibu Classic
Engine: LSx 5.3
Transmission: MN12 6-speed, 4L60E
Axle/Gears: 4th gen 3.42
Re: lm7 block deal
The engine and trans are a good chunk of the money spent on these swaps, but i'm pretty sure the actual swap itself will be more than $500 unless of course you already have alot of the conversion parts.
Old Sep 14, 2010 | 11:39 PM
SiCkRs's Avatar
Car: 91Z28
Engine: 5.7 ls1
Transmission: 4l60e
Re: lm7 block deal
Well other than what the guy is including on the post i posted wouod i still have to put in about how muh more money for i could know around how much i would need to get a loan for.
Old Sep 14, 2010 | 11:55 PM
Engine: LSx 5.3
Re: lm7 block deal
It all depends on how in depth you wanna go with your swap as to how much it will cost. You'll need: Engine and transmission swap mounts, PCM tuning, exaust, a way to regulate fuel pressure, 255 lph fuel pump, LS1 wiring modifications - contact pocket for info on this, and i'm sure I'm forgetting some other important details. It's the little things in this swap that start to add up: radiator hoses, PS pressure hose, fuel lines & fittings, etc.
Does the engine come with the harness and computer? if not, that needs to be added in there too
Old Sep 15, 2010 | 12:07 AM
SiCkRs's Avatar
Car: 91Z28
Engine: 5.7 ls1
Transmission: 4l60e
Re: lm7 block deal
Yes it includes the harness computer complete dash, fuel tank, radiator and fans too
Loudnproud86
Jul 14, 2016 12:59 AM
aharvel50
Sep 21, 2015 07:31 PM
RyanJB
Sep 14, 2015 03:39 PM
Nick McCardle
Sep 10, 2015 08:36 PM
