Truck intake Queastions??
Old Sep 13, 2010 | 08:25 PM
hicksport's Avatar
Car: 1991 vert camaro
I have a 6.0 from an 08 gmc truck, Im triing to do this swap on a budget and wuld like to use the truck intake, what hood would I need to make this work? I have already had the harness done by Waitforme performance. Thanks for any info
Old Sep 13, 2010 | 08:51 PM
Klortho's Avatar
Car: 1987 GTA
Axle/Gears: 9 bolt 3.70 posi
Re: Truck intake Queastions??
no hood would clear, there's a post that shows how high the truck intake sits at the front of the engine.
Old Sep 13, 2010 | 09:01 PM
Shift06's Avatar
Car: 1991 Trans Am GTA
Engine: LSX (swapping)
Transmission: 4L60E (swapping)
Axle/Gears: 2.73 Posi 10 Bolt
Switch to the LS1 intake, you can get them for like $40 bucks on ls1tech.
Old Sep 14, 2010 | 12:24 AM
1ADan's Avatar
Car: 1987 Trans Am
Engine: LQ9/L92
i really hate to say it, but budget's kinda hard when you go with a truck motor. i'm in the same boat, but if you've got time on your hands, it'll be less expensive. unless you can modify a lot of sheet metal, you're best bet is the ls1 intake and fbody accessories.
Old Sep 14, 2010 | 03:39 AM
BlueMagicSS's Avatar
Car: 2000 Camaro SS/86 Iroc/89 Iroc(x2)
Transmission: 6 Speed
Axle/Gears: 4.10
As it was said before, you're going to have to use an LS1 intake and f-body accessories. Look on Tech and Craigslist.
Old Sep 14, 2010 | 07:39 AM
Mkos1980's Avatar
Car: Formula
Engine: 6.0 LSX
Axle/Gears: 9 Bolt 3:27
Or Vette acc's. I think I'm one of the few running them. Couldnt find an f body setup to save my soul.
Old Sep 14, 2010 | 11:19 AM
hicksport's Avatar
I was afraid of that, the ls1 intake wont work has to be ls2, and mine has the vvt which means ill need the acc off of the newer camaro or corvette maybe cst-v? Is the camaro pan still the best option for an oil pan?
Thanks for the replies.
Old Sep 14, 2010 | 02:21 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
I have an LS2 intake available. The vacuum port on the left side behind the TB needs to be repaired or plugged (long story - I'll share it if you like). Make an offer. I'd like it to go to a good home.
The f-body pan is still the best option.
Hotrodboba400
Dec 10, 2019 07:07 PM
db057
Apr 28, 2019 07:45 AM
nugentcj
Camaros Wanted
Dec 22, 2015 02:58 PM
91L98Z28
Southern California Area
Sep 19, 2015 09:35 AM
Amillionoh7
Sep 11, 2015 11:36 AM
