89 RS LQ4 Turbo project.
Old Sep 13, 2010 | 10:50 PM
rockoosi1's Avatar
Car: 89 RS
Engine: LQ4
Transmission: TH400
Axle/Gears: Too lazy to check!!
Well, I have lurked behind the scenes long enough. I just got this puppy running and I'm now in the tuning phase. I got lots of info and ideas from this board so I figured I would throw my junk up for scrutiny. Let me know what you think.
This car had a BBC in it when I got it. It was ok but nowhere near what I wanted. I already had the 6.0 waiting for a future project so I said hmmm.
Attached Thumbnails 89 RS LQ4 Turbo project.-dsc01167.jpg   89 RS LQ4 Turbo project.-dsc01183.jpg   89 RS LQ4 Turbo project.-dsc01182.jpg
Old Sep 13, 2010 | 10:58 PM
rockoosi1's Avatar
Car: 89 RS
Engine: LQ4
Transmission: TH400
Re: 89 RS LQ4 Turbo project.
I seem to be having problems uploading pictures so let me skip to the end. If you have any questions just post them.
Attached Thumbnails 89 RS LQ4 Turbo project.-dsc01344.jpg   89 RS LQ4 Turbo project.-dsc01351.jpg   89 RS LQ4 Turbo project.-dsc01355.jpg
Old Sep 13, 2010 | 11:01 PM
rockoosi1's Avatar
Car: 89 RS
Engine: LQ4
Transmission: TH400
And a few more with it done. Sorry I can't upload more pictures.
Attached Thumbnails 89 RS LQ4 Turbo project.-dsc01427.jpg   89 RS LQ4 Turbo project.-dsc01428.jpg   89 RS LQ4 Turbo project.-dsc01429.jpg
Old Sep 13, 2010 | 11:44 PM
dynodanmanda79's Avatar
Car: 1989 IROC-Z, 1979 Malibu Classic
Engine: LSx 5.3
Transmission: MN12 6-speed, 4L60E
Axle/Gears: 4th gen 3.42
Man what a beautiful car and build you've got going, welcome to the LSX side of the house. I see that you are using a silverado upper radiator hose, are you using the truck water pump too? videos asap plz!
Old Sep 14, 2010 | 12:28 AM
rockoosi1's Avatar
Car: 89 RS
Engine: LQ4
Transmission: TH400
Yep that is a truck water pump. I will be doing some street tuning in next couple days to see how this thing runs. I will try and get some videos and post them.
Old Sep 14, 2010 | 01:09 AM
Engine: LSx 5.3
Sweet thanks, how were you able to get the ls1 intake/throttle body to work with the truck water pump? I thought there was some form of clearance issue?
Old Sep 14, 2010 | 01:42 AM
TTz31's Avatar
Car: 89 Iroc-Z28
Engine: 454 BBC
Transmission: TH400
Axle/Gears: 10 bolt 2:73 Posi
X2
Old Sep 14, 2010 | 08:49 AM
Pocket's Avatar
Car: 91 Trans Am
Looks great so far
I see now all the trouble you've been having with the wiring
Old Sep 14, 2010 | 09:54 AM
rockoosi1's Avatar
Car: 89 RS
Engine: LQ4
Transmission: TH400
Well because I'm not using cruise control I just cut off the little arm and that was it. Now because of my alternator placement I had to pull out the trusty old rubber mallet and give the upper radiator hose nipple some love & affection. It needed to rotate about 5-10 degrees but it seems to be work good so far.
Old Sep 14, 2010 | 10:00 AM
rockoosi1's Avatar
Car: 89 RS
Engine: LQ4
Transmission: TH400
Originally Posted by Pocket
Looks great so far
Yeah I spent most of my effort on building the turbo kit. I didn't realize how hard it was going to be to get the harness to tuck in as neatly as your stuff. I'm really not happy with that part of the build but I think it will be easy enough to come back and clean up later.
Thanks for all of the help BTW. You are batting a 100% in my book.
Old Oct 6, 2010 | 08:56 AM
lreflybyou's Avatar
Are those truck manifolds?
Old Oct 6, 2010 | 10:05 AM
Grifter757's Avatar
Car: 87 IROC,
Engine: 370 LSx With Boost
Transmission: 4L80E
Axle/Gears: S-60 with 3.50s
Is the manifold flange cut off and the welded to other pipe?
Old Oct 6, 2010 | 01:24 PM
rockoosi1's Avatar
Car: 89 RS
Engine: LQ4
Transmission: TH400
I'm using a truck manifold on the passenger side and a F-body on the driver's side. I had to cut the truck flange off in order to clear the K-member. I then welded mild steel and a V-band. So far so good.
Old Oct 6, 2010 | 08:32 PM
Guest
Guest
Posts: n/a
Your solutions seem inspired. Good creativity there.
Old Nov 23, 2011 | 08:29 AM
rockoosi1's Avatar
Car: 89 RS
Engine: LQ4
Transmission: TH400
Re: 89 RS LQ4 Turbo project updates. She is starting to move
Well, I haven't been on here in a while so I figured I would post a quick update. I finally took this thing to the track and was very pleased .
I ran it one weekend exactly as I drive it on the street with the muffler attached and managed to go 11.2x @ 127 mph. After some suggestion from some other turbo guys, I disconnected the muffler. The next time out it literally lit my DRs up at about 60' so I had to back out of it. My ET dropped but mph still jumped to 131 mph.
My guess is if I can get a good pass in I should be able to get in the low to mid 10s @ about 135 on about 12 psi. At 3800 lbs with me in it, I'm feeling that!!!
Old Nov 23, 2011 | 09:33 AM
91kbell's Avatar
I guess that would be acceptable
Old Nov 23, 2011 | 09:38 AM
rockoosi1's Avatar
Car: 89 RS
Engine: LQ4
Transmission: TH400
LMAO!!
Old Nov 26, 2011 | 07:56 PM
Kory-88Iroc 350 tpi's Avatar
Car: 88 Iroc
Engine: 94 lt1 modded
Transmission: t 56
What size turbo is that? Do you have any more pics of the accessory drive?
Nice work.
Kory
Old Dec 8, 2011 | 03:11 PM
JAYDUBB's Avatar
Car: 1991 Camaro RS
Engine: L03 305 V-8 (for now ;) )
Transmission: T-5 5 speed
Axle/Gears: stock... whatever that means :)
Congrats again dude!
Old Apr 12, 2013 | 12:33 PM
rockoosi1's Avatar
Car: 89 RS
Engine: LQ4
Transmission: TH400
Well, I brushed the leaves and acorns of my car yesterday. This thing still tickles me every time I drive it! The last time I drove it I was going 10.6x @ 133.
I plan on going to the track this weekend to see if I can dip into the 10.4x-10.5x range. Wish me luck!
cheesehomer
Dec 31, 2015 08:48 AM
David Frans
Oct 31, 2015 08:12 PM
LT1Formula
Oct 8, 2015 08:34 PM
skinny z
Oct 5, 2015 06:23 PM
bjpotter
Oct 4, 2015 07:48 PM
