LT1 wiring problem
Old Sep 19, 2010 | 09:29 AM
chevyowner02's Avatar
Car: 1992 camaro
Axle/Gears: 3:73
LT1 wiring problem
I was helping a friend finish up the wiring on his LT we had it started. So he decides to run the ECM inside and extends the wires. Hacked up the harness pretty bad so he got one from a caprice and he decides to leave the ECM under the hood.
We wired it up again and now cant get it to turn over the starter relay is clicking thought it might be bad replaced it still nothing. We followed Pocket's wiring diagram and I believe it is wired correct.
When you go to start it the radio will shut off any ideals?
I am not much on wiring just trying to help him out. Oh yea its a 95 also.
Old Sep 19, 2010 | 11:00 AM
Pocket's Avatar
Car: 91 Trans Am
Re: LT1 wiring problem
If the relay is clicking, then its getting power and sending it through. Is the solenoid wire connected to the starter? Battery cable on the main lug?
Old Sep 19, 2010 | 03:23 PM
Car: 1992 camaro
Axle/Gears: 3:73
Yea I think so, he told me he had to put a new starter on it I was thinking if it was clicking it wasn't getting it through. But it might be the other way around.
Old Sep 19, 2010 | 04:16 PM
Pocket's Avatar
Car: 91 Trans Am
No sound means no function
Old Sep 19, 2010 | 05:17 PM
Car: 1992 camaro
Axle/Gears: 3:73
It will be this weekend before we get to work on it again, I'll check the starter just to be sure any other ideals on what else to look for?
midge54
Sep 2, 2020 07:13 PM
midge54
Dec 27, 2019 04:14 PM
Infested
May 22, 2018 11:56 PM
sreZ28
Aug 14, 2015 07:48 PM
