converting DBW harness to cable driven harness
Old Sep 22, 2010 | 04:50 PM
xpndbl3's Avatar
Car: 1984 Z28
Engine: SLOW carbed ls
Axle/Gears: moser 9" 4.11
Any insight on this or if it's possible? I have an 04 avalanche harness and need to convert it to a cable driven harness. If it's too complicated I guess I'll sell this one and buy an older harness, just this one is sitting on the engine. I already went out and bought a red/blue computer since apparently the green/blue harness I have and that computer won't work for cable driven stuff. Poking around on all data for the 04 harness and kind of lost. My first EFI swap, normally it's all race cars with carbs or big stuff 3, this is new to me. Poked around pocket's posts for a while didn't see anything like this covered. It would go into a 88 tbi/th400 "full size 4x4 thirdgen" To keep it thirdgen tech related of course.
Old Sep 22, 2010 | 05:35 PM
88 350 tpi formula's Avatar
Car: 89 FORMULA 350, 91 Z28 Convertible
Engine: ls1, LB9
Transmission: t56, Auto
Axle/Gears: S60/ 3.73
Re: converting DBW harness to cable driven harness
i saw a post about this on ls1 tech but im not sure if they had it working "correctly" yet
Old Sep 22, 2010 | 06:11 PM
89fbirdformula's Avatar
On Probation
Car: 1989 Formula,1991 z28
Engine: 400 Vortec Hsr,496bbc
Transmission: TKO600,TH400
Axle/Gears: 9"4.10, 9"3.73
Steve, just keep it DBW...toss a pedal in the burban, and call it a day, then you get the benifits of EASY cruise control, and no fiddling with having to change your cable.
Old Sep 22, 2010 | 06:45 PM
xpndbl3's Avatar
Car: 1984 Z28
DBW throttle body is gone and I have a ported/polished cable one sitting on a shelf. Also don't have the TAC module or the pedal assembly or assorted wiring for it
Old Sep 22, 2010 | 07:50 PM
Pocket's Avatar
Car: 91 Trans Am
Since you're already repinning from green/blue to red/blue just leave out the DBW connectors (2 serial wires to the TAC connector) and run new ones for the TPS/IAC. Pretty much ANY GM vehicle from the 90's up will have them in a JY
This guy has an awesome site and goes into detail about what to retain and what doesnt fit etc
http://www.lt1swap.com/cable_conversion.htm
Old Sep 22, 2010 | 08:48 PM
xpndbl3's Avatar
Car: 1984 Z28
whew, i'll need to read this over a lot apparently for this all to make sense.
Old Sep 22, 2010 | 09:26 PM
Engine: ls1, LB9
I think this would be the way to go..
Vintageracer
Jan 10, 2020 05:33 PM
9192camaro
16
Feb 3, 2019 12:21 AM
stalkier
Aug 21, 2015 01:54 AM
355tpipickup
Aug 19, 2015 10:02 PM
