Where are you guys putting your computers on your swaps?
Old Oct 1, 2010 | 02:28 PM
jimmy92rs's Avatar
Car: 1992 RS
Engine: 01' LS1
Axle/Gears: 10 bolt auburn pro posi, 4.10 gears
Im in the process of locating my pcm for my ls1 swap to the inside of the car. The problem is that the pcm doesnt reach to the factory 3rd gen computer location. The wires are to short and dont reach. Im sure some have ran into this problem. I was wondering what you have done to make it work? Please dont mind the dusty engine bay and paint.
Old Oct 1, 2010 | 02:35 PM
Shift06's Avatar
Car: 1991 Trans Am GTA
Engine: LSX (swapping)
Transmission: 4L60E (swapping)
Axle/Gears: 2.73 Posi 10 Bolt
Re: Where are you guys putting your computers on your swaps?
Lengthen the wires. I had Pocket make me a harness and thats what he did for me.
Old Oct 1, 2010 | 05:43 PM
1ADan's Avatar
Car: 1987 Trans Am
Engine: LQ9/L92
i lengthened my wires so i could follow the factory route. I also grabbed a bulkhead connector from the junkyard so I could gut it and run everything through the factory spot in the passenger footwell
Old Oct 1, 2010 | 06:51 PM
Pocket's Avatar
Car: 91 Trans Am
Lengthen the wires and/or move the hole closer to the engine
Old Oct 1, 2010 | 11:00 PM
Mkos1980's Avatar
Car: Formula
Engine: 6.0 LSX
Axle/Gears: 9 Bolt 3:27
Factory route and location..
Old Oct 2, 2010 | 01:07 AM
ZONES89RS's Avatar
Car: 86 TA, 91 B4C
Engine: 5.3, 4.8
Transmission: 4L80 4000, T56
Axle/Gears: 4.30 M12, 23.42 10 bolt
LOL:
Old Oct 2, 2010 | 01:17 AM
stoning_volcom's Avatar
Car: 98 Camaro Z28
Engine: 346 LS1
Axle/Gears: 3:43
since i am no longer gonna have heat or ac i am gonna mount right where the blower motor sat
Old Oct 2, 2010 | 08:30 AM
Pocket's Avatar
Car: 91 Trans Am
Why not heat? Gets mighty cold in IL
Old Oct 2, 2010 | 08:43 AM
sargenewk17's Avatar
Car: 92 Camaro RS
Engine: LS2
Axle/Gears: 12-Bolt with 3.73
mine's in the factory location, even using the factory plastic bracket which I trimmed to make it fit
Old Oct 2, 2010 | 05:38 PM
jimmy92rs's Avatar
Car: 1992 RS
Engine: 01' LS1
So if I drill a new hole closer to the engine then the pcm will fit in the factory location? Also if lengthening the pcm wiring, should I use the soldering method or the heat shrink butt connector method? This is going to be time consuming!
Old Oct 2, 2010 | 07:08 PM
1ADan's Avatar
Car: 1987 Trans Am
Engine: LQ9/L92
solder! its more reliable and less likely to cause issues. plus it will keep down the pysical size of the wiring bundle.
Old Oct 2, 2010 | 07:11 PM
Pocket's Avatar
Car: 91 Trans Am
Up to you to redrill a hole. Id lengthen the wires since the hole is already there
DO NOT USE BUTTCRIMPS FOR PCM WIRES EVER. Solder is the only option you should consider for this
Old Oct 2, 2010 | 09:19 PM
TPI TERR's Avatar
On Probation
Car: 87 IROC-Z
Engine: LsX
Transmission: MN12 6speed
Axle/Gears: 3:42
Extended 3 feet sits hidden beneath my 4th gen dash
Old Oct 3, 2010 | 08:57 PM
87CIZ's Avatar
Car: 88' Iroc-Z
Engine: LQ9
where do you guys get the extra wire to lengthen it? another harness?
Old Oct 4, 2010 | 01:43 AM
iansane's Avatar
Car: '91 TA vert
Engine: turboLSx
I mounted mine in the thirdgen location and used extra wire from one of the many harnesses I've scrounged.
Old Oct 4, 2010 | 02:03 AM
MotorMouth's Avatar
Car: 1992 Camaro RS
Engine: 305 TBI
Why no A/C either really gets hot too.
Old Oct 4, 2010 | 12:43 PM
jimmy92rs's Avatar
Car: 1992 RS
Engine: 01' LS1
sounds like ill be lengthening these wires....
Old Oct 8, 2010 | 09:58 PM
jimmy92rs's Avatar
Car: 1992 RS
Engine: 01' LS1
does anyone know what the metri pack terminal part number is that is in the pcm blue and red connectors? I have an idea........
customblackbird
Aug 15, 2021 10:16 PM
jharrison5
Aug 19, 2015 05:53 PM
Zachattack0925
Aug 12, 2015 09:54 PM
Zachattack0925
Aug 12, 2015 09:52 PM
Jake_92RS
Aug 11, 2015 10:39 AM
