Hooked up the LS1/4L60E PCM brake signal, seems happier
Transmission: 4L80E/4L80E
In the rush to get the car running in early September, I didn't get around to hooking up some of the "nice-to-haves", or so I called them. Finally hooked up the signal to the PCM for the brake status (12v + = brake "off"), discovered the '86 cruise control switch already did that. Spliced it into the PCM line, TCC lock-up is much better now.
Still need to hook up the Cable X box to get the speedometer working, SES (MIL) light, and OBD II port. Should get to those this week.
Tonight, hopefully. If the light is on, I'll retrieve the codes.
NBrehm
Aug 25, 2015 11:49 PM
