LSX oil leak
Old Oct 5, 2010 | 08:48 PM
candy burple rs's Avatar
Car: 87coupe,91RS Camaro's, 00 Suburban
Engine: LSX427HO w/D-1SC and intercooler
Transmission: RPM Tremec T-56 Magnum
Axle/Gears: DTS 12bolt, 3.42
LSX oil leak
Got to ask a question. i have a first year block (LSX), the back plate on the rear of the motor is leaking after 20 seconds of run time at idle.
The 3 bolts on the driver side or (left) have oil lines coming from them. These are the ones frome the bottome of the oil pan up. I have done everything the builder asked but still leaks...I was wondering if I could put air to the oil galley to see if the bolt holes will bubble when air is put to the block. Before I send the motor back....the bolts are backed buy a galley and my belief is that there is a crack. I have used anarobic goo on the bolts and it still bleeds....so anybody have any suggestions..
the seal, rear main, the oil redirection plug and everything else has been went through and not messed up..
Last edited by candy burple rs; Oct 5, 2010 at 09:40 PM. Reason: have a pic to add
Old Oct 6, 2010 | 05:45 PM
Pocket's Avatar
Car: 91 Trans Am
Re: LSX oil leak
Post up on 'tech. You and Neil are the only LSX guys I know of
LSX blocks have a different rear cover than other LSx engines so something had to have changed. For LSx blocks, theres an oil galley plug that goes in there, but you shouldnt build oil pressure at all without it. IIRC the cover bolts should be blind depth and not go into anything oil related, but again this is LSx stuff, not LSX like you've got
Hotrodboba400
Dec 10, 2019 07:07 PM
hdis2002
Sep 8, 2015 02:52 PM
dmtz956
LSX and LTX Parts
Sep 6, 2015 04:45 PM
tgp1990
Sep 4, 2015 06:24 AM
Hotrodboba400
Sep 2, 2015 07:28 PM
