How much work to go from a V6 to a carbed LT1?
Old Oct 3, 2010 | 09:26 PM
Camrs89's Avatar
Car: 91 Formula, 79 Trans Am, 72 LeMans
Engine: 305 TPI, 6.6, 350 Pontiac
Transmission: T5, 3 speed, TH350
Going to be buying a disassembled LT1 to put together for my 91. It currently has a v6 though. Whats all needed to convert the car to a carbed LT1 engine?
I have a v8 T5 to replace the V6 T5 and v8 sway bar, springs, and gauge cluster. I know I will need a radiator as well. What else will I need?
Old Oct 4, 2010 | 08:18 AM
Pocket's Avatar
Car: 91 Trans Am
Re: How much work to go from a V6 to a carbed LT1?
90-92 V6 radiators are the same as 82-92 V8 rads, only 82-89 had a smaller unit for V6's. You're fine, single fan will be ample as well
Also, LTx engines were designed around EFI. It's silly to revert to a carb
Old Oct 4, 2010 | 08:52 AM
Falconiroc's Avatar
Car: 1991 RS
Axle/Gears: 4.11
I'm with Pocket on that one. There is absolutely no benefit to going with an LTX motor if you are ditching the EFI, thats the whole benefit.
Old Oct 4, 2010 | 11:18 AM
Camrs89's Avatar
Ill need a new one though because LT1s are reverse flow with the coolant system. Going carbed right now but may convert to fuel injection when I have extra cash.
Old Oct 4, 2010 | 12:01 PM
Klortho's Avatar
Car: 1987 GTA
Axle/Gears: 9 bolt 3.70 posi
It will cost you as much to go carbed as it will to go FI on the LT1
Old Oct 4, 2010 | 03:38 PM
Zepher's Avatar
Car: 86 Trans Am, 88 Formula
Engine: 95LT4, 305TPI
Transmission: T56, T5
depends on what all he has with the LT1.
Carb will be much easier.
k-member, front coil springs, fuel lines, 6-15psi electric fuel pump, carb intake, carb, distributor, modified radiator for steam lines from the LT1. that is the bulk of it.
Old Oct 4, 2010 | 06:55 PM
Pocket's Avatar
Car: 91 Trans Am
Reverse flow coolant has no bearing on radiator type
Old Oct 5, 2010 | 02:01 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
Doesn't really depend upon what you have with the LT1. Even with a bare long block, you can complete it with used parts for no more than the specialized LT1 carb parts will run you.
Old Oct 5, 2010 | 03:20 PM
Zepher's Avatar
The intake is $270
http://www.jegs.com/i/GM%20Performan...0002/-1?CT=999
carb is what, $300, dist $100-180, ign box $150.
It's not really that bad.
what other special parts are needed?
Old Oct 5, 2010 | 05:13 PM
five7kid's Avatar
A "real" carb is more like $450 (putting an Edelbrock carb on an LT1 is pouring lemon juice on a paper cut). Don't forget fuel pressure regulator, fuel line adapters, air cleaner, throttle cable (unless you're starting with a TBI car), throttle cable bracket - all the little things that nickle & dime you to death.
Quick search on eBay, found a complete LT1 engine in Wisconsin for $250. The OP should be able to drive up there and pick that up. Another complete engine/trans/harness/PCM for $700 in Connecticut. Or a complete '96 LT1/T56 drop-out harness/PCM/radiator/lines in Florida for $1500.
In all honesty, what we have here is another example of starting with too little and expecting too much. It would make more sense to pay the shipping for that engine/trans from Florida than it would to take a local bare longblock and try to build around it.
Old Oct 5, 2010 | 09:34 PM
Camrs89's Avatar
I found a traditional SBC 350 that Im going to use instead. Should be easier and cheaper to build. Plus I believe its a 4 bolt main block if I want to go nuts later
Old Oct 6, 2010 | 05:20 PM
five7kid's Avatar
It will be cheaper, and it will be easier. Go for it.
(You're still going to need a lot of "stuff", since you're going from V6 to V8.)
Old Oct 6, 2010 | 05:22 PM
five7kid's Avatar
Although that LT1/T56 would be a guaranteed "ear-to-ear" without going nuts...
Old Oct 6, 2010 | 05:46 PM
Pocket's Avatar
Car: 91 Trans Am
You've got to change the stuff for any generic SBC, why not go for a newer more efficient engine with an extra gear to bang out?
Old Oct 6, 2010 | 06:42 PM
Camrs89's Avatar
We will see what comes along, Im selling a bunch of stuff so Ill see how much I can gather together for a engine, possibly a trans. For right now, the 91 is just going to be a cruiser, want it to sound good and look good, as long as it has some power, Ill be happy. Heck, even a 305 I would be content with. I have a 450 HP 72 GTO and a 375 HP LT1 Camaro if I want to go fast.
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
customblackbird
Oct 1, 2015 04:30 PM
thekurlyone
Sep 30, 2015 12:54 PM
lanceflame44
Sep 25, 2015 12:28 PM
jerflash
Sep 24, 2015 03:11 PM
