Strut tower braces that fit with LSX swap
Old Nov 11, 2010 | 05:12 PM
Aussie Camaro's Avatar
Car: 91 RS Right hand drive
Engine: Soon to be LSX
Transmission: Soon to be 4L60E
Axle/Gears: 10 bolt 3.23
Can someone tell me if this strut brace will fit over an LS1 conversion?
Thanks guys.
http://performanceparts.com/part.php?partID=135917
Old Nov 11, 2010 | 07:01 PM
Pocket's Avatar
Car: 91 Trans Am
Re: Strut tower braces that fit with LSX swap
It will fit fine
LSx engines using car style intakes are significantly lower than TPI/TBI's
Old Nov 11, 2010 | 09:59 PM
Thanks for the quick reply.
I actually wanted to use this type of strut brace because it looks better:
http://performanceparts.com/part.php?partID=135918
BUT I'm a bit afraid of the part that says "Some vehicles may require trimming of hood understructure"
Old Nov 11, 2010 | 10:13 PM
Stephen's Avatar
Car: 87 GTA
I know that the GTA hood commonly has fit problems, due to its inner structure.
I don't know of any Camaro hoods that cause any problems, but the Camaro nose is a tad higher above the STB location.
Old Nov 12, 2010 | 07:43 AM
Pocket's Avatar
Car: 91 Trans Am
Camaro hoods are so high they dont even need a trim to fit HSR
Pretty much any STB made to fit a stock engine will fit your engine bay
Look at all that room!
https://www.thirdgen.org/forums/post...72-post61.html
Old Nov 12, 2010 | 07:41 PM
Awesome it does look like there is a heap of room in there. Cheers
Frozer!!!
Jan 19, 2024 04:55 PM
customblackbird
Aug 15, 2021 10:16 PM
Nervous2
LSX and LTX Parts
Mar 10, 2016 09:49 PM
ASE doc
Alternative Port EFI Intakes
Aug 25, 2015 09:14 AM
