LT4
Old Nov 15, 2010 | 09:03 PM
jchaussee's Avatar
Car: 85 Z28
Engine: 327
LT4
Has anybody swapped in an LT4. I know a lot of guys do LT1 but I was curious about LT4. If so , some pics would be sweet.
Old Nov 16, 2010 | 02:14 AM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Re: LT4
It is only a LT1 with special parts so the swap is no different
Put the LT4 engine covers on a LT1 , paint the intake red and few would know the difference
Old Nov 16, 2010 | 12:59 PM
scrubbin627's Avatar
Car: 1995 Camaro z28
Engine: 355 LTX
Axle/Gears: 4.10
Re: LT4
agreed. The main differences are inside.
bigger cam
better heads with larger valves
rocker arms
different piston and rings
28lb injectors
better intake (red)
roller timing set
better crank
4 bolt main with stronger caps
..and a few other little things like teflon rear main, better head gaskets...etc. You could easily mod a regular LT1 to smoke a LT4, its just being a real "LT4" is why I would love to have one. I have never seen one in a third gen. Unless someone really wanted one, its kind of a expensive swap for just 30 more hp.
Old Nov 16, 2010 | 01:15 PM
thewizard's Avatar
Car: LT4 C4, LT1 CE, 95' Dyno Air
Transmission: ZF S6-40, 4L60E, sprockets
Axle/Gears: 3.45, 3.07
Re: LT4
30 hp is what GM claimed. Most LT4 Vettes will dyno just shy of 300 at the wheels and run high 12s bone stock all day long, whereas LT1 Vettes pull 13.6s.
Old Nov 16, 2010 | 02:13 PM
jchaussee's Avatar
Car: 85 Z28
Engine: 327
Re: LT4
I don't think they would be much more expensive then an LT1. It is just finding one. Saws a gut in england selling one complete for 1200 puonds which I think is around 3K. I also saw a guy claiming to have a vette he was selling thi 78K miles for 6500 with an LT5. Though I would have gto claim BS on that one
Old Nov 16, 2010 | 08:18 PM
vetteoz's Avatar
Car: 82 Z28
Transmission: T400
Re: LT4
4 bolt main with stronger caps .
All Vette LT1's are 4 bolt mains
http://www.grandsportregistry.com/lt1vslt4.htm
Old Nov 16, 2010 | 08:21 PM
third gen luver's Avatar
Re: LT4
k
Old Nov 16, 2010 | 08:25 PM
Re: LT4
im haveing some problems out of my 89 iroc i seen someone on here wit the same problem but didnt get to see what was causeing it. it smokes when i start it up and when its ideling but clears up when im runing it and it the plugs are burning real clean with now oit and it doesnt use oil can someone give me some advice
Old Nov 16, 2010 | 08:29 PM
Engine: 355 LTX
Axle/Gears: 4.10
Re: LT4
So were all the factory replacements.
Old Nov 16, 2010 | 08:36 PM
kevinc's Avatar
Car: 1982 Z28
Re: LT4
Apart from the red intake manifold, what difference are you expecting to see?
Old Nov 16, 2010 | 08:38 PM
kevinc's Avatar
Car: 1982 Z28
Re: LT4
My advice would be to fix it.
Old Nov 16, 2010 | 08:43 PM
jchaussee's Avatar
Car: 85 Z28
Engine: 327
Re: LT4
That is excactly what I want to see. I want to see the red intake inside a third gen camaro engine bay. I just like to look at engines.
tommy z-28
Oct 6, 2015 10:58 PM
thekurlyone
Sep 30, 2015 12:54 PM
TX-SleeperC5
Sep 24, 2015 03:13 PM
ssgt usaf
Sep 21, 2015 12:45 PM
1988iroc350tpi
Aug 14, 2015 07:52 PM
