what do you think so far ls6
Car: 92 z28 vert
Engine: ls6
Transmission: t56 magnum
Axle/Gears: moser 9 inch 4.11
i have been working on my porject for about 8 months i dont have much time to work on it because i work about 70-80 hours a week but i am getting there slowly it is a 92 z28 convertible with 60,000 miles and not a spot of rust anywhere it has been tore apart and stripped almost all body work is done it is getting painted infero orange metalic off of a 2010 camaro just started it up 2 weeks ago and it sounds good with the open headers here is a list of parts that i have
race craft k member,lower control arms,c/c plates, 2 inch drop spindles
ls6 out of 04 zo6
t56 magnum tremec offset shifter
hawks trans cross member
moser 9 inch with detroit truetrac 4.11 gear
bmr trac pack torque arm
hotchkis trailing arms and pan hard bar
spohn sfc's
c6 z06 front and rear calipers and rotors
hawks long tube headers
borla exhaust cat back
kyb agx shocks and struts
getting to buy ms4 cam and springs
and many other new parts that is packed away
let me know what you think so far
ls6 out of 04 zo6
spohn sfc's
Car: 92 Firebird
Engine: 4.8 LR4
Axle/Gears: 3.45 9 Bolt
Re: what do you think so far ls6
OK I have to ask, wha is with the wheel studs in the shifter?
Also with this much clearance you can consider running a different pan, maybe one with more baffling in it,
The rest of the pictures with nothing in the car but the engine are really cool looking
Car: 92 z28 vert
Engine: ls6
those studs was the only bolt that i had sitting around at that time, just temp
Car: 1987 Trans Am
Engine: LQ9/L92
i've seen those hoses in stock at my local advance - not sure the application, but they've got that 90 degree bend at one end and like 3-4 feet of straight hose from there. been keeping an eye on em for when i do my heater core hoses. need something simple and uncluttered, think you're route looks the best so far without having to hack and get adapters
Car: camaro sportcoupe
Engine: 7.0L
Transmission: G-Force GF5R
Axle/Gears: Moser 9"
those hoses aren't application specific btw, they're just a universal type with a 90* end on one end and are available at most any parts store
What he said, and wow...that is so much cleaner! I think I need to change my set up a bit. I have those 90* jobbers, but I have the short side attached to the heater core. And with the FRC, it hides all that mess. Good stuff!
Engine: Cammed 6.0L LSX
Clean swap so far, keep it up
Car: 1989 IROC-Z, 1979 Malibu Classic
Engine: LSx 5.3
Transmission: MN12 6-speed, 4L60E
Axle/Gears: 4th gen 3.42
Buggy Disaster
Sep 22, 2015 01:15 PM
