lsx radiator hoses
Old Nov 24, 2010 | 08:40 PM
chris lo's Avatar
Car: 92 z28 vert
Engine: ls6
Transmission: t56 magnum
Axle/Gears: moser 9 inch 4.11
lsx radiator hoses
what upper and lower radiator hoses are you guys using on your lsx
Old Nov 24, 2010 | 08:49 PM
one92rs's Avatar
Car: SOLD!!!!!
Re: lsx radiator hoses
https://www.thirdgen.org/forums/sear...archid=3307810
Old Nov 24, 2010 | 08:55 PM
1nasty86's Avatar
Car: 1986 camaro
Engine: ls2
Transmission: FLT stage 6 60e
Axle/Gears: 8.8 with 3.73's
stock 02 f body hoses.
Old Nov 25, 2010 | 11:18 AM
sargenewk17's Avatar
Car: 92 Camaro RS
Engine: LS2
Axle/Gears: 12-Bolt with 3.73
4th Gen V6 hose for top and '90 F-250 lower hose. The lower one gets tricky, though, because IIRC it has to be for a truck w/out air conditioning and it has to be from Gates. You have to trim it a bit. If you search on here you'll find the exact part number; there are entire threads on it.
Old Nov 25, 2010 | 11:23 AM
Car: 92 Camaro RS
Engine: LS2
https://www.thirdgen.org/forums/ltx-...-radiator.html
Old Nov 25, 2010 | 05:44 PM
ShMaCk2004's Avatar
Car: 1987 Camaro IROC-Z
Transmission: LS1 T56
Axle/Gears: Richmond 3.73
LS1 4th gen radiator and hoses
Old Nov 26, 2010 | 09:47 AM
1ADan's Avatar
Car: 1987 Trans Am
Engine: LQ9/L92
great link, that's where i got my info from
lower - dayco D71321
upper - dayco E71321
Old Nov 26, 2010 | 11:03 AM
Mkos1980's Avatar
Car: Formula
Engine: 6.0 LSX
Axle/Gears: 9 Bolt 3:27
I used an upper hose from a 3.4L 4th gen and the lower is a Mr.Gasket universal one. It fits great, doesnt touch anything and was 25 bucks from summit.
Old Nov 26, 2010 | 03:51 PM
Omega's Avatar
Car: 89 Formula / 09 G8
Engine: LS1 / LS3
Transmission: M6 / M6
Axle/Gears: 3:42 / 3:27
I used a Dayco 71321 for the lower hose. It was a MUCH better fit than the previous hose (no clue which one)
Old Nov 26, 2010 | 08:14 PM
88 350 tpi formula's Avatar
Car: 89 FORMULA 350, 91 Z28 Convertible
Engine: ls1, LB9
Transmission: t56, Auto
Axle/Gears: S60/ 3.73
both upper and lower 98-02 ls1 f-body hoses with out p/s cooler, just flip the lower one so the big end is at the radiator. Best fit out of all the hoses
Pac J
May 17, 2020 10:44 AM
sheachopper
Jul 31, 2019 11:27 AM
