LT1 corvette ACC. mounting bracket necessary parts?
Car: 1989 RS Camaro
I have a 89 RS Camaro I'm, swapping a 95' 9C1 caprice cop car LT1 & 97 SS Camaro T56 6 speed. I bought a LT1 corvette accessory mounting bracket to relocate my a/c compressor, etc. to prevent notching my K member etc. I was just curious what parts I will need to buy to make this corvette' ACC. bracket setup mount & work. Any help is greatly appreciated, thanks.
Re: LT1 corvette ACC. mounting bracket necessary parts?
With LT1's the accy's are an all or nothing deal. None of the indiv pieces interchange directly from Fbody to Bbody to Ybody
Car: 1981 Camaro; 1986 Z28
Engine: LT1; LT1
Transmission: 6 speed; 6 speed
Axle/Gears: 3.73; 3.42
Yup. Everything is different. Even the opti has the plug on the opposite side. Hopefully you got all everything with it cuz the compressor, alternator, coil bracket and pump were different on the vette. You shouldn't have any worries with the pump and opti harness but the rest might get expensive.
Terrell351
Jun 13, 2021 01:13 PM
