LSX Swap Finishing
Old Apr 6, 2011 | 05:31 PM
  #51
TheMuskr's Avatar
Car: 89 IROC Z28 Vert
Re: LSX Swap Finishing
wow sweet swap. should be sick when its all wrapped up
Old Apr 7, 2011 | 09:50 AM
  #52
ShiftyCapone's Avatar
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
Very nice swap! Do you have any othe pics of the coils? Looks very clean. Also, did you say you got that motor for $4k! Where?
Old Apr 7, 2011 | 11:54 AM
  #53
90-irocdx3's Avatar
Car: 1990 iroc z
Engine: LSX 376 F1A
Transmission: 4l60e
Axle/Gears: 12 bolt 3.42
ha ha yes i did get the motor for 4k, I actually bought it from a guy who won the motor. A little risky since I didn't know the guy, but you can tell this motor has never been fired still had all the factory gm tape and oil with the blank pan. I won't be able to put some pics up until the 16th but i will see if my dad can shoot some pics for me earlier.
Old Apr 7, 2011 | 12:09 PM
  #54
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
Makes sense now. I would say you got a heck of a deal on that.
Old Apr 19, 2011 | 07:13 PM
  #55
90-irocdx3's Avatar
Car: 1990 iroc z
Engine: LSX 376 F1A
Transmission: 4l60e
Here is a picture with the coils. I am just finishing up making the wires. Monday the car goes to the exhaust shop in the morning, then off to tuning in LA. I actually bought the double hump hawks 4l60 crossmember and modifying it to fit a 700r4 trans. Here is a more current picture with the coils mounted and connected. Name:  PICT1150.jpg
Old Apr 21, 2011 | 06:17 PM
  #56
90-irocdx3's Avatar
Car: 1990 iroc z
Engine: LSX 376 F1A
Transmission: 4l60e
All done underneath the hood, except radiator blew up!
Old Apr 21, 2011 | 08:52 PM
  #57
M G Brewer's Avatar
Car: 1988 IROC-Z
why does white always look so good?
Old Apr 22, 2011 | 03:27 AM
  #58
Demon355's Avatar
Looks awesome! What accessories are you running? I've read through the thread but just forget.
Old Apr 22, 2011 | 03:53 PM
  #59
90-irocdx3's Avatar
Car: 1990 iroc z
Engine: LSX 376 F1A
Transmission: 4l60e
I am running f body accessories.
Old May 2, 2011 | 06:15 PM
  #60
90-irocdx3's Avatar
Car: 1990 iroc z
Engine: LSX 376 F1A
Transmission: 4l60e
Yes i cut both sides to make sure it was centered. With my last set up i had long tubes but it was just terrible ground clearance always bottoming out. Plus I needed to tuck up two high flow cats up there too. I have only two pic's from the tow truck taking it to the dyno shop. It really doesnt do justice though. by the way my car is lowered 1 1/2 inches.
Old May 3, 2011 | 03:48 PM
  #61
Demon355's Avatar
Time to get a hawks trans x-member. Why not put the cats after the headers?
Old May 3, 2011 | 03:54 PM
  #62
hellz_wings's Avatar
Car: 1986 Chevrolet Camaro IROC-Z28
Engine: TPI 310ci (LB9)
Transmission: Custom Rebuilt 700R4 - 2600 Stall
Axle/Gears: 10 bolt, 3.73 Eaton Limited-Slip
DAmn that looks way too low! You'll scrape everything
Old May 3, 2011 | 04:31 PM
  #63
last_'s Avatar
Car: 91 Camaro RS
Axle/Gears: stock...
This really makes me nervous seeing as I am lowering mine 2" .. what the hell was i thinking!??!?
Old May 3, 2011 | 04:41 PM
  #64
90-irocdx3's Avatar
Car: 1990 iroc z
Engine: LSX 376 F1A
Transmission: 4l60e
They angle i took the picture makes it appear lower than it is. I am using the hawks crossmember it's modified to fit a 700r4 transmission. I tried to put the cats closer to the headers, there just wasn't enough room. My exhaust, I doubt it will hardly scrape compared to my last setup. I have stiff suspension too.
Old May 3, 2011 | 08:13 PM
  #65
last_'s Avatar
Car: 91 Camaro RS
You wouldnt happen to know the spring rates would you? And I keep hearing about this hawks crossmember.. is it good? I cannot seem to find it on there website.
Awesome build as well!
Old May 3, 2011 | 08:40 PM
  #66
90-irocdx3's Avatar
Car: 1990 iroc z
Engine: LSX 376 F1A
Transmission: 4l60e
I am running hotchkis springs, with agx shocks set at the firmest setting. there is not a 700r4 crossmember made by hawks yet. Although they did tell me they are currently working on one into production. My crossmember was a 4l60 cut and modified to fit a 700r4 trans.
Old May 7, 2011 | 03:38 PM
  #67
fun Pain's Avatar
Car: 1987 Formula 350
Engine: 6.0 boost and smak
Transmission: 4l80e
Axle/Gears: 9bolt 3.27
what a beeeaaaa uuuut.... very nice sir
Old May 18, 2011 | 05:56 PM
  #68
90-irocdx3's Avatar
Car: 1990 iroc z
Engine: LSX 376 F1A
Transmission: 4l60e
well the car is running now.
Old May 18, 2011 | 06:07 PM
  #69
last_'s Avatar
Car: 91 Camaro RS
i opened the link, it said video not found. bummer love seein others running or in the works lsx/ltx or whatever swaps.
Old May 18, 2011 | 10:01 PM
  #70
90-irocdx3's Avatar
Car: 1990 iroc z
Engine: LSX 376 F1A
Transmission: 4l60e
here is a new link
http://www.youtube.com/watch?v=jfBofy2v5zE
Old May 19, 2011 | 07:30 AM
  #71
last_'s Avatar
Car: 91 Camaro RS
nice!
Black89TA
Exterior Parts for Sale
Jul 23, 2016 10:42 AM
Orr89RocZ
Apr 25, 2016 08:28 AM
Nervous2
LSX and LTX Parts
Mar 10, 2016 09:49 PM
InfinityShade
Aug 22, 2015 08:00 PM
jharrison5
Aug 19, 2015 05:53 PM
