OBDII wiring
Old Dec 7, 2010 | 09:23 AM
techrunner's Avatar
Car: 91 Formula
Engine: lq4
Transmission: t-56
OBDII wiring
ok, i think this is right, but i want to check before i wire it up and fry something. i have an 03 6.0 with its ecm and harness, DBW. for the obd II connector, theres a pin Blue 52, drk grn, which says serial data. is that the on e i use for the obdII connector to tune with?
Old Dec 7, 2010 | 01:24 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
Should be right. That's the way I hooked mine up, and a scanner was able to read it. No smoke escaped as a result.
Old Dec 7, 2010 | 02:06 PM
Pocket's Avatar
Car: 91 Trans Am
Re: OBDII wiring
Its B58 for the Red/Blue PCMs. Check the pinout on your DBW PCM, might have moved but I doubt it
Glowsock
Jan 9, 2017 04:06 PM
Caspar
Jun 19, 2016 11:19 PM
ndndndnd
Carburetors
17
Sep 5, 2015 06:24 PM
Bryan F
Aug 27, 2015 07:28 AM
Bert87
Aug 23, 2015 03:50 PM
