350 for LS motor??
Old Jan 4, 2011 | 09:21 PM
Thirdgen82's Avatar
Car: 1982 Camaro Z28
Engine: 350 small block
350 for LS motor??
i had my 350 rebuilt in march for my 82 camaro and i have had some problems with hoses radiators and heating and other things...would switching to a ls motor change some of these problems? also can i get a ls6 for a 04 vette??
Old Jan 4, 2011 | 09:52 PM
BlueZee28's Avatar
Engine: Cammed 6.0L LSX
Re: 350 for LS motor??
You do realize that swapping to an LS1 is going to cost a lot more than fixing your cooling problem right? (assuming you don't need a new block or anything like that). If it's just hoses or gaskets, it's a lot cheaper to fix what you've got. This isn't the only reason you are contemplating doing the swap is it? There's gotta be another reason otherwise I can see this one being a swap that's never finished.
My $0.02
Old Jan 4, 2011 | 10:34 PM
Iroc'nthe87's Avatar
It will only complicate them.
Old Jan 5, 2011 | 12:40 AM
Prokilllsx's Avatar
Car: OVRMYHD
Engine: H/C/I LS1
Transmission: 4L60E 3,200 Edge stall
Axle/Gears: 9 bolt w/3.90
I say get the car to a good mechanic and correct your current cooling issues.
Study up on the costs and complexities of an LS swap.
If you decide to go ahead with the swap, save up the expected expenses while locating a highly recommended LS engine/ swap mechanic.
If you get all those ducks in a row, go for it.
Old Jan 5, 2011 | 07:20 AM
1ADan's Avatar
Car: 1987 Trans Am
Engine: LQ9/L92
gotta agree with the other responses - an LSx swap is awesome, but its a lot more expensive then just replacing some cooling system parts. There is a lot of time and money needed to do this swap the right way. Even being "frugal" puts you in for a few thousand and a lot of time waiting for deals.
Get the issues you're having now cleared up so you can drive the car and then start reseaching and buying parts for the swap
Old Jan 5, 2011 | 07:10 PM
kevinc's Avatar
Car: 1982 Z28
Sort of like asking "I have trouble mopping my floor, would building a new house solve this problem?"
I posted some advice in your Cooling thread, take a look and follow up w/ results.
You have our permission to get whatever you can find and afford.
theshackle
Sep 17, 2020 08:26 AM
theshackle
Mar 5, 2017 06:37 PM
Mickeyruder
Sep 2, 2015 02:45 PM
Out-Cast
Aug 17, 2015 10:57 AM
st.evel07
Aug 13, 2015 06:15 PM
