Quick question
Old Jan 13, 2011 | 10:51 PM
native1031's Avatar
Quick question
Thinking of a LT1 swap on my 84 z28. I can use the same drive shaft correct? Or are they diff lengths?
Old Jan 13, 2011 | 11:41 PM
jaymoung's Avatar
Car: 1984 Camaro z28
Engine: 350 small block
Transmission: 350 Turbo
Re: Quick question
diff tranny so driveshaft i believe but i hear ppl cut and weld on engineswaps when the driveshaft is too long or too short
Old Jan 13, 2011 | 11:49 PM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Re: Quick question
What trans are you going to use?
Trans length is what determines DS length not engine
Old Jan 13, 2011 | 11:52 PM
vetteoz's Avatar
Car: 82 Z28
Transmission: T400
Re: Quick question
Originally Posted by jaymoung
diff tranny
Why?
LT1 has std SBC bolt pattern so you can bolt up any Chevy trans ( within reason )
Early LT1's came with the 4L60 (T700) trans just like 3rd gen did
Old Jan 13, 2011 | 11:57 PM
jaymoung's Avatar
Re: Quick question
Originally Posted by vetteoz
Why?
Tranny have different lengths some have short tails some have long tails
Old Jan 14, 2011 | 01:28 AM
native1031's Avatar
Re: Quick question
Well im looking at a 97 camaro. All I know is it has an LT1 with original rebuilt transmission.
Would the automatic 700r4 be capable? Thats what I have in now
Old Jan 14, 2011 | 09:07 AM
1ADan's Avatar
Car: 1987 Trans Am
Engine: LQ9/L92
Re: Quick question
the motor and trans will fit in without issue and you can reuse your ds. the motor and trans from the 4th gens are the same length as the 3rd gens and the 4th gen aluminum ds's are a very common swap for the 3rd gen steels.
Old Jan 14, 2011 | 12:28 PM
native1031's Avatar
Re: Quick question
Nice thanks for the info
Old Jan 14, 2011 | 02:42 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
Re: Quick question
Get the engine AND transmission. It doesn't make a lick of sense to put an old TH700 behind an LT1 - the LT1 has a "PCM" - "Powertrain Control Module" - that controls both the engine and transmission. The 4L60E in the '97 is superior in all ways to any TH700.
The 3rd gen torque arm and driveshaft are both interchangeable with the 4th gen units (as long as we're not talking about the early 3rd gen 3-speed auto and 4-speed manual transmission models). While you're at it, you might as well get the driveshaft out of the '97 as well, as many of them were aluminum, and had a damping ring built into the transmission yoke.
Old Jan 14, 2011 | 03:33 PM
native1031's Avatar
Re: Quick question
I didnt plan on using the 700R4 just didnt know you could use it.
Thanks Five7Kid you answered my next question about the ds
redmaroz
Aug 16, 2015 11:40 PM
happyhapka
Aug 15, 2015 04:42 PM
jahblah
Aug 12, 2015 05:54 PM
