LS1 Swap- ECM Mounting Location?
Old Jan 17, 2011 | 09:18 PM
Nervous2's Avatar
Car: 1985 TRANSAM
Where to mount the ecm on a third gen transam ls1 swap?
Old Jan 17, 2011 | 10:36 PM
25thAnn_RS's Avatar
Car: 92 Camaro RS
Axle/Gears: 4.10
Re: LS1 Swap- ECM Mounting Location?
I put mine in the stock location. there was really no "mounting" exactly. It will stay up on its own. I drilled a hole in the firewall for the wiring harness. I did my swap in a camaro but it should still work the same.
After I ran the wiring.
Under the dash before I closed up the dash.
Old Jan 18, 2011 | 07:24 AM
Pocket's Avatar
Car: 91 Trans Am
Its in the sticky
https://www.thirdgen.org/forums/ltx-...third-gen.html
https://www.thirdgen.org/forums/ltx-...ing-under.html
Mines closer to the engine than others posted
http://i150.photobucket.com/albums/s...1/DSC01816.jpg
http://i150.photobucket.com/albums/s...1/DSC01803.jpg
Old Jan 18, 2011 | 10:28 AM
1ADan's Avatar
Car: 1987 Trans Am
Engine: LQ9/L92
i put mine in the stock location as well. I gutted a spare ecm harness bulk head to use the factory hole in the passenger fender well.
Old Jan 18, 2011 | 03:16 PM
25thAnn_RS's Avatar
Car: 92 Camaro RS
Axle/Gears: 4.10
I wanted to run mine the same way, but I didn't want to lengthen all the wires. As it was they were barely long enough. Though it probably looks a lot cleaner than mine.
Old Jan 18, 2011 | 03:43 PM
1ADan's Avatar
Car: 1987 Trans Am
Engine: LQ9/L92
I cringe at how bad my first attempt looks at the pcm end, but it was my first time doing something like this, so mistakes were made while learning a lot. I'll probably pick up another harness to work on before the next swap and clean things up a bit.
as for now, it all hides behind the dash, so my bird's nest of a mess is out of sight
Old Jan 19, 2011 | 09:03 PM
White'89's Avatar
Car: '89 GTA
Engine: 5.7L LS1
Axle/Gears: 9 bolt 3.27
Same here Dan. I wish I would have cut each end even and had all my extensions be the same length, but I didn't and it was awful. I'm just crossing my fingers and hoping that all my solders will hold out ok and that none of the sensors will read wrong....
Orr89RocZ
Apr 25, 2016 08:28 AM
smokingss
LSX and LTX Parts
Mar 3, 2016 07:40 PM
sreZ28
Aug 14, 2015 07:48 PM
3rdgenparts
Exterior Parts for Sale
Aug 8, 2015 11:48 AM
