Trade 4L60E harness plug for 4L80E ?
Old Jan 19, 2011 | 12:45 PM
xpndbl3's Avatar
Car: 1984 Z28
Engine: SLOW carbed ls
Axle/Gears: moser 9" 4.11
Anyone out there doing a harness swap and have a 4L80E plug and want to put a 4L60E in their camaro? I'm willing to swap my plug for that one. I have the wires complete to the computer pinouts all bundled up nicely.
Old Jan 19, 2011 | 01:05 PM
techrunner's Avatar
Car: 91 Formula
Engine: lq4
Transmission: t-56
Re: Trade 4L60E harness plug for 4L80E ?
do you have a pic of the one you need? i might still have the plug in my wiring box if you know what it looks like. its off an 03 silverado 2500, so it should be the 4l80 plug.
Old Jan 19, 2011 | 01:20 PM
Pocket's Avatar
Car: 91 Trans Am
The connector is the same for 4L60E's and 80E's. The pinout is what changed
Only the very early 4L80E's (90-91) used a special bolt on connector
Old Jan 19, 2011 | 01:42 PM
xpndbl3's Avatar
Car: 1984 Z28
hmmm really. I was under the impression the shapes of the connectors were different as well. In that case what pins do I need to move around?
Old Jan 19, 2011 | 02:42 PM
Pocket's Avatar
Car: 91 Trans Am
http://www.performancetrucks.net/for...ghlight=4l80e\
You need to add an ISS connector if using a 60E harness. Find one in a JY, any 2 wire CTS or 98+ VSS connector will do
Old Jan 19, 2011 | 04:02 PM
xpndbl3's Avatar
Car: 1984 Z28
ISS connector is not the VSS connector on my harness that I have now? Or am I missing something?
Old Jan 19, 2011 | 09:16 PM
Pocket's Avatar
Car: 91 Trans Am
80's have two VSS inputs. The Rear one which is what you have reads the output shaft speed and drives the speedo. The ISS is located up front and measures the speed of the internal bits. Not really sure of its purpose further than it's required to function
Green and purple are the rear, blue and red are the ISS
midge54
Sep 2, 2020 07:13 PM
crt454
Interior Parts Wanted
Jun 23, 2017 02:25 PM
smokingss
LSX and LTX Parts
Mar 3, 2016 07:40 PM
Reddeath210
Oct 6, 2015 08:20 AM
jharrison5
Aug 19, 2015 05:53 PM
