LS1 swap for my '89 GTA
Old Mar 22, 2011 | 01:11 PM
  #101
Pocket's Avatar
Car: 91 Trans Am
Re: LS1 swap for my '89 GTA
Question for Pocket: do I need to label all of the wires when I remove them since I am going to have you rework my harness for me?
Sure dont! Pull it and send it as-is with whatever gremlins the PO left in there. Ill sort them out for you
Old Mar 22, 2011 | 01:41 PM
  #102
dprest68's Avatar
Car: 1989 Pontiac Trans Am GTA
Engine: cammed LS1
Transmission: Monster SS 4L65E
Axle/Gears: 9 bolt posi w/ 3.70 gears
That's what I kind of figured, but I thought I should at least ask.
Old Mar 22, 2011 | 09:41 PM
  #103
cprmn14's Avatar
Car: 91 RS
Engine: LTwon
Axle/Gears: Both
Looking good!
Taking the motor out has been my favorite part of my swap so far.
Old Mar 22, 2011 | 09:51 PM
  #104
dprest68's Avatar
Engine: cammed LS1
Thanks man! I'm a little anxious about taking my engine out actually. The last engine I took out of a third gen took two solid days. I am dropping this one out of the bottom though. So I think it should be much easier. I won't have to label everything either, so that should speed up the process.
Old Mar 23, 2011 | 07:37 AM
  #105
Pocket's Avatar
Car: 91 Trans Am
Just a tip to speed things along. Leave everything imaginable attached to the engine when it comes out. Harness, accessories, intake, belt even
Old Mar 23, 2011 | 08:37 AM
  #106
dprest68's Avatar
Engine: cammed LS1
Thanks for the tip. I'm glad you said that. I was going to remove the harness, but it does make more sense to leave it on there. I had already planned on leaving everything else on there.
Old Mar 25, 2011 | 11:20 PM
  #107
dprest68's Avatar
Engine: cammed LS1
I was just goofing around today and put one of my G8 wheels on the front of my car. It looks odd because the front left was on a jackstand so that I could put the wheel on. I couldn't get the wheel on because the hub sticks out too far. You would need at least a 1.5" wheel spacer to get it on there. I think it might look pretty cool with those on there. What do you guys think? There would be plenty of room for a big brake kit for sure
Old Mar 26, 2011 | 10:13 PM
  #108
dprest68's Avatar
Engine: cammed LS1
Well, I was supposed to go to a car show with a friend this weekend, but decided to work on getting the engine out of my car instead. I made some decent progress. I am just taking it slow since I have never dropped an engine out the bottom before.
Pocket, you said to leave the harness on the engine. Is that the harness that runs over top of the a/c box and into the passenger side fender?
Old Mar 27, 2011 | 08:06 AM
  #109
Pocket's Avatar
Car: 91 Trans Am
Unhook the C100 and lay it over the engine
Unplug the ECM and C207 then pull them out from behind the fender and lay them over the engine
Drop assembly
Old Mar 27, 2011 | 09:15 AM
  #110
dprest68's Avatar
Engine: cammed LS1
Well, that sounds easy enough. Is the C100 under the master cylinder? Sorry, I'm a newb at all this wiring stuff
Old Mar 27, 2011 | 09:51 AM
  #111
BlueZee28's Avatar
Engine: Cammed 6.0L LSX
yep right under the brake booster. There's a 1/4" bolt right in the center of it that you'll need to loosen (it won't come all the way out because it's built into the connector), then you just pull it off the firewall.
Old Mar 27, 2011 | 10:05 AM
  #112
dprest68's Avatar
Engine: cammed LS1
That's what I thought. Thanks Nick.
Old Mar 27, 2011 | 04:18 PM
  #113
dprest68's Avatar
Engine: cammed LS1
I got the computer down from under the dash and disconnected. I'm assuming the C207 is the plug-in beside the yellow box in this pic.
Anyone know what the yellow box is for? ...holy crap my carpet is dirty!
This thing holding the wiring harness in place was being a bugger!
It took some finessing, but I finally got it out.
Old Mar 27, 2011 | 04:31 PM
  #114
dprest68's Avatar
Engine: cammed LS1
One more pic of the harness being pulled out
I didn't think I was going to be able to get that big square thing through this hole, but I got it to work. One step closer...
Old Mar 27, 2011 | 05:01 PM
  #115
White'89's Avatar
Car: '89 GTA
Engine: 5.7L LS1
Axle/Gears: 9 bolt 3.27
That brings back memories of laying upside down in the passenger seat...
Old Mar 27, 2011 | 05:10 PM
  #116
HP52TA's Avatar
Car: 89 WS6 TransAm
Engine: LQ408
Transmission: T56 Magnum
Axle/Gears: Strange S60, 4.10s
Keep up the great pictures and details. You're a couple steps ahead of me and this will be a great reference when I get to installing the computer.
That big block connector can be taken apart and reused for your new wiring. When I rewired my car for the previous carb setup, I heated it with a hot air gun until the whole thing was very hot. It then pulled apart quite easily. There is a locking clip that has to be removed as well.
  #117
1ADan's Avatar
Car: 1987 Trans Am
Engine: LQ9/L92
the yellow box has to do with your factory speedo, pretty sure its gotta be bypassed, but memory's a bit rusty
Old Mar 27, 2011 | 06:05 PM
  #118
Pocket's Avatar
Car: 91 Trans Am
Yellow box is your buffer. Remove and connect pins C to F
http://www.austinthirdgen.org/mkport...SS_V8_vinE.jpg
What happens with the old fender grommet is your call. Routing the long way behind the fender you hollow it out. Cutting a hole under the HVAC box for a more hidden install you take the old grommet and plug the hole in the fender leaving the wire stubs intact
Old Mar 27, 2011 | 07:48 PM
  #119
dprest68's Avatar
Engine: cammed LS1
Yeah, fun stuff! That was probably the easiest part of my day though.
Old Mar 27, 2011 | 07:52 PM
  #120
dprest68's Avatar
Engine: cammed LS1
Thanks man! Yeah, I tried for awhile to get it apart, but gave up. I figured there was a trick to it. I didn't think I could get it through the hole in the fender at first. I got it to go through the second time I tried it though. So that made me happy
Old Mar 27, 2011 | 07:55 PM
  #121
dprest68's Avatar
Engine: cammed LS1
Ah, okay. Thanks Dan. They say the memory is the first thing to go when you get old! j/k
Old Mar 27, 2011 | 08:02 PM
  #122
dprest68's Avatar
Engine: cammed LS1
Thanks for the info. Pocket. Good information. I haven't decided which way to go yet though. I usually like trying to keep most stuff stock looking, but I also like hiding wiring as much as possible too. I will have to think about that one.
So swapping pin C over to pin F changes the pulses per mile from 2000 to 4000, correct?
Old Mar 27, 2011 | 08:16 PM
  #123
dprest68's Avatar
Engine: cammed LS1
HOLY CRAP! I didn't realize I was going to have to do battle with the frickin Harness Monster! I'm not quite sure if I won or lost! Here's a pic of the slayed beast...
Good thing I killed when I did! It was about to devour my engine I had to unbolt my headlight and the crossbracing to to get everything out.
I guess it would have been a bit easier to unbolt all of the body parts up front. Darn that hind sight.
I had my grandpa and my daughter help me take the hood off. It makes it so much easier to get to everything.
I'm assuming there are some ground straps on the back of the heads that connect to the firewall that I will also have to disconnect. I think I got the one on the passenger side. I haven't looked at the driver's side yet.
Old Mar 27, 2011 | 08:18 PM
  #124
dprest68's Avatar
Engine: cammed LS1
Oh, and my grandpa said he would help me drop the engine. So that's cool. It's always nice to have an extra pair of hands.
Old Mar 28, 2011 | 01:11 AM
  #125
dprest68's Avatar
Engine: cammed LS1
Alright, I think I got everything disconnected and ready to drop. I got a nice ATF bath when I pulled the driveshaft out. That was fun.
I only saw the one ground strap from the engine to the firewall on the passenger side. I thought there was one on both sides on the last T/A engine I pulled, but I could be wrong.
Looks like pretty much all I have left to disconnect is the front suspension, trany crossmember & brake lines. Can I just drop the cat forward exhaust with the engine assy.?
Old Mar 28, 2011 | 05:58 AM
  #126
1ADan's Avatar
Car: 1987 Trans Am
Engine: LQ9/L92
Attachment 216357
I dunno how I missed this post too. You beat me to it! I was hoping to see how mine looked on the TA too, gotta say not bad seeing your photo. Bet you could find some of these 18s for cheap-ish on the G8 boards, since everyone wants the GT/GXP rims. I'd personally LOVE a set of the GXP 20s on the G8, but waaaaay too much coin for a daily driver......
Old Mar 28, 2011 | 08:44 AM
  #127
Pocket's Avatar
Car: 91 Trans Am
Not really. You unplug the box, then splice the input to the output so the signal goes strait through from your PCM to the C207 to the speedo
Ahh, a bit too far there. From the firewall booster the C100 splits into two halves. Engine half and light half. The light half isnt touched for the swap is is a monster to remove
One ground strap is all you get. Undo the trans lines at the radiator, coolant lines at the rad, heater core lines at the firewall and rad, front brake lines at the provp valve, trans crossmember, front K-member brace triangles, and 4 of the 6 K-member bolts
Last 2 bolts should be all that remains
Old Mar 28, 2011 | 11:23 AM
  #128
dprest68's Avatar
Engine: cammed LS1
Man, I thought I had figured out that diagram you put on here Pocket. I guess not Man I suck at wiring
Ah CRAP! I didn't even think about that harness. I was just getting into ripping wiring out! Oh well. If I decide to paint my engine bay, at least that wiring will already be removed.
Thanks for reminding me about the triangle braces.
If I am going to switch over to digital cruise control, what should I do with the wire and hose that appears to come through the firewall for the old cruise control unit?
Old Mar 28, 2011 | 11:27 AM
  #129
Pocket's Avatar
Car: 91 Trans Am
Some connectors are salvaged but the majority goes away
Old Mar 28, 2011 | 11:29 AM
  #130
dprest68's Avatar
Engine: cammed LS1
Yeah, it probably would look pretty cool if you had the correct spacers on there and it was sitting on the ground at ride height. I was thinking you might be able to find them at some local junk yards too. I might try that later down the road. Yeah, those GXP 20's are sweet.
Old Mar 28, 2011 | 11:31 AM
  #131
dprest68's Avatar
Engine: cammed LS1
Are you talking about for the cruise control?
Old Mar 28, 2011 | 12:58 PM
  #132
Pocket's Avatar
Car: 91 Trans Am
Yes
Old Mar 29, 2011 | 01:41 PM
  #133
dprest68's Avatar
Engine: cammed LS1
I spent a bunch of time last night trying to figure out a way to get the coil spring compressor to work on this car. Didn't have much luck though. Is that why you guys use chains instead? I do have an idea that I might explore though.
Old Mar 29, 2011 | 09:04 PM
  #134
dprest68's Avatar
Engine: cammed LS1
Ha! My idea for my spring compressor worked. One side is disassembled. Lucky I had an extra nut that was the same size as the threaded rod on the spring compressor.
I put the floor jack under the control arm.
Removed the strut bolts, then lifted the control arm more to compress the spring more. Then I tightened the nut on the spring compressor and ran the rod up higher so that the lower control arm would clear it.
Old Mar 29, 2011 | 09:11 PM
  #135
dprest68's Avatar
Engine: cammed LS1
After I lowered the control arm down, all I had to do was use a pry bar to slide the spring out. No problems at all. It worked like a champ.
All I had to do after that was loosen the nut on the compressor and release all of the springs energy.
Let's hope the other side goes even smoother!
Old Mar 30, 2011 | 04:56 AM
  #136
Jaysz28's Avatar
Car: 91 Firebird
Engine: 6.0
Looks like good progress man!
Old Mar 30, 2011 | 09:24 AM
  #137
dprest68's Avatar
Engine: cammed LS1
Yeah man! I plan on dropping the engine out on Saturday.
Old Apr 1, 2011 | 05:13 PM
  #138
dprest68's Avatar
Engine: cammed LS1
Does the steering center link need to be removed to drop the engine? It looks like it's going to be in the way.
Old Apr 1, 2011 | 05:25 PM
  #139
Pocket's Avatar
Car: 91 Trans Am
I dropped it with the engine because i didnt have a pickle fork. Id assume it has to be taken loose at minimum because it's right under the balancer
Old Apr 1, 2011 | 06:34 PM
  #140
dprest68's Avatar
Engine: cammed LS1
Yeah, that's what I thought. I removed it and swung the pitman arm towards the frame. Hopefully that will be enough. I think I have it all ready to drop in the morning. Woo hoo!
Old Apr 2, 2011 | 01:54 PM
  #141
dprest68's Avatar
Engine: cammed LS1
The engine has been removed! Lots of progress pics to be posted soon. It only took us about two hours to get it out of there. It's definitely a two person job
Pics to follow...
Old Apr 2, 2011 | 02:03 PM
  #142
dprest68's Avatar
Engine: cammed LS1
Ready to get started...
We had to keep the cherry picker hook above the core support so as to not damage the condenser. I also cut open one of the old hoses length-wise and put it over the core support metal so that it didn't get damaged. It worked real good.
hooks are attached to the radiator support under the frame. I can provide a better pic if anyone want to see where exactly the hooks were installed to lift the front end
She's going down captain!
Old Apr 2, 2011 | 02:14 PM
  #143
dprest68's Avatar
Engine: cammed LS1
slowly, but surely...
...And the ref throws the flag for interference!
Another flag thown for interference?
Once I removed the alternator, it solved my two interference problems and we were able to continue.
Old Apr 2, 2011 | 02:23 PM
  #144
dprest68's Avatar
Engine: cammed LS1
...A little bit closer
And just like that, BOOM, it's out! YAY! We had to remove a few more things to get it out, but we made it work.
Good thing we were able to get it out at this height, because the boom was against the nose of the car We also had to rotate the cherry picker around to the passenger's side of the car to make it easier to get the engine assy. out from underneath the car.
I'm trying to see if Summit will sponsor my swap now
Old Apr 2, 2011 | 02:49 PM
  #145
dprest68's Avatar
Engine: cammed LS1
Here are the extra parts that I needed to remove to get the engine out...
I know it sounds weird, but I also had to remove both dipsticks. It would have been easier to have both control arms removed too since they interferred with the cherry picker legs.
So... I'm thinking I had an oil leak... or five! That's only a fraction of the oil. It was everywhere. So I'm thinking the valve cover gaskets were the culprit.
The cat forward exhaust dropped with the engine with no problem.
Now we're getting somewhere...
I am SOOOOOO glad to have the engine bay looking like that! Can't wait to put the new engine in there. But first... lots of cleaning and painting. I don't think the Gunmetal Grey engine bay looks too bad, but I want to clean it up to see exactly what I'm working with.
Old Apr 2, 2011 | 05:09 PM
  #146
HP52TA's Avatar
Car: 89 WS6 TransAm
Engine: LQ408
Nice job on documenting your removal, I was wondering where guys were hooking up to lift without damaging something. Not a whole lot of height to spare with the cherry picker.
Having an empty engine bay makes a guy feel like he has a fresh piece of canvass ....
Old Apr 2, 2011 | 06:46 PM
  #147
dprest68's Avatar
Engine: cammed LS1
Ah thanks. Yeah. not much room to spare at all.
Yes, that's true. Hopefully I can make a masterpiece
Old Apr 2, 2011 | 06:49 PM
  #148
dprest68's Avatar
Engine: cammed LS1
After having removed the engine now out the bottom for the first time, I definitely can say that I like doing it that way much better. The engine that I pulled on my other GTA I pulled out the top and hated every minute of it!
Old Apr 3, 2011 | 09:57 AM
  #149
dprest68's Avatar
Engine: cammed LS1
Some more empty engine bay pics...
Here is half of my garage full of engines and transmissions!
What a mess!
Old Apr 3, 2011 | 10:04 AM
  #150
dprest68's Avatar
Engine: cammed LS1
Here is my new engine with the third gen a/c compressor installed (upper left)
And here is where I installed the hook on the passenger's side to lift the front end. We hooked it in the same place on the driver's side. It basically uses the sheet metal to keep the hook in place and pulls up on the bottom of the frame.
