5.3 in a 85 z28
Old Jan 27, 2011 | 01:00 AM
91lsz28's Avatar
Car: 85 z28
Engine: 305 4bbl
5.3 in a 85 z28
i have been doing the research on this i wanna do a carbed 5.3 swap. i read u can do the basic swap for $2500, now my question is could i do this. This would be my first full on motor swap by myself, i know my around a car its what im going to school for after all and what time frame would this take to do. I dont go back to school till spring so could this be done farley soon i dont work right now i got layed off so i have all the time right now.
thanks
Old Jan 27, 2011 | 07:34 AM
ShiftyCapone's Avatar
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
Re: 5.3 in a 85 z28
It all depends on the parts you have lined up and if you have done your research.
You are going to be hard pressed to do this for $2500. Its the little things that add the cost to these swaps (exhaust, fuel, wiring, motor mounts etc).
There is no set answer on timing. I would take the time now to read as much as you can in this forum as well as over on LS1tech.com.
Old Jan 27, 2011 | 07:58 AM
1ADan's Avatar
Car: 1987 Trans Am
Engine: LQ9/L92
Re: 5.3 in a 85 z28
I agree on all points
gotta do as much reading as you can. gather all the wiring diagrams you can, purchase a helms manual for your vehicle. even going carbed, there are areas you need to splice and rewire in your car.
$2500 is really not going to cut it. the carb swap stuff alone will eat a good chunk of that budget. then comes the exhaust work, all the accessory stuff (since the truck stuff doesn't fit), and any adapters you need transmission wise. If you have *lots* of time, you can sit back and hunt for deals (my route), but its going to be a while.
if you haven't done a motor swap before, this is going to be a challenge, definitely not what i'd recommend for a first time, but its doable if you do your research and take your time
ZZ3Astro
Aug 13, 2019 12:57 AM
BADNBLK
Convertibles
65
Feb 10, 2016 03:36 PM
customblackbird
Oct 1, 2015 04:30 PM
Amillionoh7
Sep 11, 2015 11:36 AM
