Getting started with my first lt1 swap. need segestion.
Old Jan 29, 2011 | 07:16 PM
white camaro rs's Avatar
Transmission: 5 speed
I have a 92 camaro rs 5 speed with a 305 wana be tpi. but I messed up at some point that my engine is over heating. So I am thinking of just buying an lt1.
I am located in smyrna GA, so if any one have lt1 let me know.
I have a regular transmition that came with a car which is a 5 speed.
Everything at this moment works, but it just holds at high apm's and over heats in 10 or 15 min. everything was done correctly.
Also, I have no hp or torque, and it back fires like crazy. It don't want to go fast. if u might have an idea let me know.
So, as soon as i get LT1 engine, since I already changed my wiring harnes, when i installed tpi in 305, with a computer and fuel pump, will I need to replace wiring harnes?
I have read that lt1 fits in 3gen, but it wont read the speed, and will not shift right, in my case I have a five speed, no worries. And I already have an aftermarket speedometer.
I know when I be putting in lt1, I will have to eliminate air conditioning. So the job would be easier. That's fine too.
Also, i have a stuck headers, I was tolled they would feat ok, and my y-pipe goes right into a glass pack. so I dont think I will need another y pipe to match it to lt1, if it wound I can always make it....
is there anything else I am leaving behind? if so plz let me know... this will be my first swap, and I want it to go as smooth as possible
Old Jan 29, 2011 | 07:53 PM
Re: Getting started with my first lt1 swap. need segestion.
http://www.youtube.com/watch?v=-myJMQ3OZA0
http://www.youtube.com/watch?v=70DQ54yQvmQ
look at this two vidios, and let me know if they work. my camaro
Old Jan 29, 2011 | 08:06 PM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
https://www.thirdgen.org/forums/engi...questions.html
Old Jan 29, 2011 | 08:09 PM
vetteoz's Avatar
Car: 82 Z28
Transmission: T400
I have a 92 camaro rs 5 speed. have a 305 wana be tpi.
I messed up at something that my engine is over heating.
I have a stuck trany.
everything at this moment works, but it just holds at high apm's and over heats in 10 or 15 min
Also, I have no hp or torque. also it back fires like crazy.
If I could understand what you are saying then maybe could help
Clean the question up detailing what you have done and tested and post it over in TPI section
What is a "stuck" trans
Old Jan 29, 2011 | 08:42 PM
Sorry, I mean a regular transmition that came with a car.
I have swaped from TB, to TPI. changed wiring harness, and computer. everything is done. but still have problems.
put new injecters. and a fuel pump.
Old Jan 29, 2011 | 08:46 PM
vetteoz's Avatar
Car: 82 Z28
Transmission: T400
Run this question in TPI dept.
https://www.thirdgen.org/forums/tpi/
Do you have correct chip for TPI in computer?
Sorry, I mean a regular transmition that came with a car..
you mean STOCK not stuck
Old Jan 29, 2011 | 08:54 PM
sorry spelling, remember for latter. I have the computer and the chip tested. and it is good. but cant find out why its over heating. its not a water pump, or any think out side of the engine.
Thank u for the web cites. but I still dont get a lot. since I already changed the wiring, I dont think I will have to do it again. one think I got straight, that my stock headers will work fine, it just i might need to get my Y pipe to fit.
BTW, and how else will I be able to test the chip or the ECU...... I will take a picture of it tomorrow and post it...
Old Jan 29, 2011 | 10:30 PM
vetteoz's Avatar
Car: 82 Z28
Transmission: T400
but cant find out why its over heating. its not a water pump, or any think out side of the engine. ..
Two things
Does the fan turn on when it is supposed to?
If your timing is out then engine will run like crap ( no power ) and also overheat
Old Jan 29, 2011 | 10:37 PM
the thing is, I had a problem with the fan before, so I wired the fan with a switch. and I did get the timing right couple of times, but it always jumped
Old Feb 5, 2011 | 09:43 PM
Well just bought me an LT1 with out trany. so I am hooking I am guessing I will be hooking it up to my stuck 5 speed. And I have modified my y-pipe the red-neck stile... so will find out if that will fit good.....
Will start pulling out my engine hopefully tomorrow and will find out what will happen.
Got an Lt1 with 56k miles for only 1,000$ and all the wires with computer and everything that comes with it. will see if its good to be true.
Old Feb 5, 2011 | 10:02 PM
cuisinartvette's Avatar
Car: 67 ******mobile
Engine: 385 Solid roller
Axle/Gears: 4.11
LT1 is one piece rear main seal, check into compatibility of flywheel/clutch.
You using the optispark setup? Accessories brackets etc?
I hope it all works out but it would be so much easier to plop a Gen 1 350 in it and convert the LT1 intake to use on it.
midge54
Dec 27, 2019 04:14 PM
midge54
Jan 29, 2017 07:00 PM
Orr89RocZ
Apr 25, 2016 08:28 AM
sreZ28
Aug 14, 2015 07:48 PM
1992 Trans Am
Aug 8, 2015 08:16 PM
