Best K member For my Set Up?
Old Feb 7, 2011 | 07:28 PM
hicksport's Avatar
Car: 1991 vert camaro
I know this has been asked before but I need some good advise on this. I will be using the stock A-arms for now. Just seems like a tubular k member would make things a ton easier for the swap. This is a car that will be driven daily but not every day, it will see high speed duty and some drag use. So please share some info with repect to my swap descision.
Old Feb 8, 2011 | 12:24 AM
Pocket's Avatar
Car: 91 Trans Am
Re: Best K member For my Set Up?
Stock K-member can be used under some conditions
Fbody LS1 oil pan is a must. Using 1" setback adapter plates with SBC mounts or spohn swap mounts it will clear, but only just barely. Several people notch it anyways. I didnt notch it the first time but if I were to do it again, I would cut it
LS1 AC compressor requires a notch. Non-AC swaps or those using the custom bracket to mount the 3rd gen or aftermarket compressor up high on the pass side do not require a notch
Old Feb 8, 2011 | 12:37 AM
QwkTrip's Avatar
COTM Editor
Car: '89 Firebird
Engine: 7.0L
How close is the engine to the A/C box when the engine is set back?
Old Feb 8, 2011 | 05:26 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
It isn't the front/back that gets close to the A/C box, it's the ignition coil. Truck coils mount up higher on the valve cover than than f-body coils, so the truck parts are often used to get the needed clearance.
1992 Trans Am
May 10, 2023 07:19 PM
customblackbird
Aug 15, 2021 10:16 PM
thefirebirdm@n
South Central Region
Sep 14, 2015 01:45 PM
lt1z350
Aug 28, 2015 05:57 AM
Linson
Aug 21, 2015 02:12 PM
